Timbren / Air Bags / Springs -- Let's Talk Cost
Last activity 2010-03-25 8:14 AM
17 replies, 11984 views
barry
Posted 2010-03-18 12:06 PM (#117770)
Subject: Timbren / Air Bags / Springs -- Let's Talk Cost
Ok, I've read the comments about the above in numerous past posts. Here is what I've found on costs in the Kansas City area.Firestone AB with compressor $900 installed. Requires some modification to fit with BW GN hitch.Timbrens $194 not installedHellwig Helper Springs $314 not installedMy 1st choice would be ABs. But I could get both Timbrens and Helper Springs for half the cost. So if I were to choose NO ABs because of cost should I do both the Timbrens & Springs or one or the other. Even for the people who swear by airbags would you still swear by them for the difference in cost?
captclank
Posted 2010-03-18 2:37 PM (#117772 - in reply to #117770)
Subject: RE: Timbren / Air Bags / Springs -- Let's Talk Cost
As for me, the cost savings of the Timbrens and installing them myself in 30 minutes was well worth it. My 3/4 ton squatted 5 1/2" before Timbrens and 2 1/2" after with my big LQ. I have no experince with the air bags or springs. Good luck!
Posted 2010-03-18 3:12 PM (#117774 - in reply to #117770)
I don't use any after market "helper springs", but if I had to choose today, I would get the Timbrens. Cheap, light weight, easy to install, not much chance of them springing a leak!!
http://www.timbren.com/
Posted 2010-03-18 6:47 PM (#117775 - in reply to #117770)
I have the Firestone Airbags. No compressor. I check the air pressure 4-5 times  a year and they stay inflated and do just fine. They have been on my truck more than 4 years. No leaks or problems. Air bags with no comrpessor will be $270-$290 for parts only.  It takes an hour to install.
I leave mine set at 20 psi for my gooseneck.  If I load up a heavy bumper pull, I might bump the pressure up another 10psi for that load.
The compressors are nice, but not neccessary.  When I sold my trailer,. the fellow that bought it, backed up to the hitch, using a camera with a dash monitor, once the ball was under the hitch, he used his compressor to inflate his air bags and lift the ball into the hitch and take the weight off the jack stand.  Got out of the truck and put the jack away, closed the coupler, hooked up the chains and drove off. I was impressed but not enough to spend the money an on board compressor cost.
whitewood
Reg. Jun 2009
Posted 2010-03-18 8:10 PM (#117777 - in reply to #117770)
Our shop put on 20 timbren's to one set of air bags. great product. Leave the top spacer out for a better ride
genebob
Reg. Nov 2007
Posted 2010-03-18 10:16 PM (#117781 - in reply to #117770)
I put the Firestone Air Bags in also. $275 installed w/o compressor. I admit I'm in a small town and my mechanic is a good friend and works cheap, sold them tome @ cost.
The truck I put them on is also our family vehicle (01' F350 CC SRW SB) We like them because they also change the ride with no trailer. I let air out to about 15# last October after last trailer pull and haven't touched them since. They've been on the truck for almost three years in the worst of Minnesota weather with no problems.
barry
Posted 2010-03-19 7:13 AM (#117787 - in reply to #117770)
Thanks all. My B&W under bed hitch plates and brackets are directly over the axle (ball just in front of axle). One trailer shop told be they had to modify all the airbag kits to make them fit. One shop trailer shop told me they would not install airbags on a truck with a BW hide/ball hitch. Anyone had any experiences with this issue?
BEN
Reg. Jun 2005
Posted 2010-03-19 8:00 AM (#117789 - in reply to #117787)
Posted 2010-03-19 8:36 AM (#117790 - in reply to #117770)
I don't know what truck you are putting them on,  I have a 2006 F350 with the B&W Turnover and my Firestone Air bags went in just fine.  It's been four years since I installed them, if I remember right there were two models of bags, one for trucks with out the B&W and one for trucks with the B&W.   Just buy the right model and you shouldn't have to modify anything .  At least on the Fords.
Safet
Reg. May 2009
Posted 2010-03-19 8:40 AM (#117792 - in reply to #117770)
Painted horse, where did you get your air bags?  Did you install them yourself?
genebob
Reg. Nov 2007
Posted 2010-03-19 11:14 AM (#117800 - in reply to #117770)
I've got the Pop-Up hitch in mine and it did not affect the installation. You can order them for different trucks. LB, SB, Ford, Chevy, DRW, SRW, etc.
Posted 2010-03-19 12:52 PM (#117805 - in reply to #117770)
I did install them myself.   It took 60-90 minutes to do.  They pretty much bolt on, No special skills necessary.  I did have to drill two holes in my bumper where I mounted the air valves by my license plate.
I ordered them from some place online.  Just google Firestone Airbags and you'll get lots of places that sell them.   Prices will run from $275- $300  for the airbags.
headhunter
Reg. Oct 2004
Posted 2010-03-19 2:30 PM (#117809 - in reply to #117770)
50010010025
We are having this conversation at my house currently too. Hubby asked the diesel specialty shop where we get our rigs serviced their opinion on Timbrens vs airbags, and they said airbags would be the same cost installed as Timbrens. Personally, I think there is less to go wrong with Timbrens so I'm leaning that direction. But I'm following this thread with great interest.
Tresvolte
Reg. Feb 2008
Posted 2010-03-19 2:36 PM (#117810 - in reply to #117770)
I've had air bags on several trucks. Never had the Timbrens. Heard good things about them though. The only issue I ever had on airbags was at the fill valve. The inside of the stem started leaking. Replaced it and had no more problems. They are really pretty straightforward and simple.
barrelhorses
Reg. Feb 2009
Posted 2010-03-19 9:12 PM (#117829 - in reply to #117810)
I've had Timbrens on two trucks now.  Great product, easy install.  Install them and never worry about them again.
genebob
Reg. Nov 2007
Posted 2010-03-20 11:34 AM (#117852 - in reply to #117770)
As far as problems with air bags, almost all semi tractors have been using them for I don't know how many years. Millions and millions of miles, Good enough for them, good enough for me.
okie ann
Reg. Jul 2009
Posted 2010-03-25 8:12 AM (#117985 - in reply to #117770)
i have the airlift in mine, control both bags from inside the truck. company stands behind their product faithfully. chevy garage punctured one of the bags and airlift replaced the bag, never cost me a cent. by the way i reminded the chevy garage to not lift the truck by the frame 3times when making the inital appt.
when i went to the airlift dealer he told me he had been a dealer for 10 years, only had problems with one system in all that time.
just thought i would add my opinion.
okie ann
Reg. Jul 2009
Posted 2010-03-25 8:14 AM (#117987 - in reply to #117770)
forgot to add that the inital cost to install the syatem was $565.00 including labor.
