Sundowner Stereo systems
Last activity 2010-03-14 8:46 PM
3 replies, 4126 views
To Much Trouble
Reg. Dec 2009
Posted 2010-03-13 4:20 PM (#117549)
Subject: Sundowner Stereo systems
I am having a bit of trouble with the stereo system in my Sundowner trailer...it started out as the outside speakers not working...after inspection, we got 1 to work..the other never did come on...Inside we checked out the stereo system ( pulled it out of the wall) and checked all conection..still didn't get the speaker to work and discovered 2 speakers inside are dead also... it is a Falcon Am/Fm cassette stereo...Hubby is thinking about replacing with a newer system... (lose the cassette and get one w/ CD
anyone else have problems, and what was your solution..any advise on how to proceed..reccommdations?
THANKS
Posted 2010-03-13 9:39 PM (#117557 - in reply to #117549)
Subject: RE: Sundowner Stereo systems
Take the wires from a working speaker and attach them to the amp on the terminals of a non working speaker. If you then have sound, the original speaker has failed. If you still do not have sound, the amp is probably bad and a new unit is in order.
Posted 2010-03-13 9:44 PM (#117559 - in reply to #117549)
Also check to make sure your speaker balance control is centered, and not adjusted for full volume on one side or another.
To Much Trouble
Reg. Dec 2009
Posted 2010-03-14 8:46 PM (#117586 - in reply to #117559)
THANKS...I will try that...
