Sundowner Lite Trailers
Last activity 2017-06-09 11:43 AM
10 replies, 18418 views
ponytammy
Posted 2010-03-09 7:26 PM (#117397)
Subject: Sundowner Lite Trailers
500100100252525
I'm helping a friend look for her first LQ trailer. Can someone help me determine what years of Sundowner had the issues with the aluminum skin over the steel frame. Was that on the value-lite or sun-lite? I'm confused with the lite trailers!
Safet
Reg. May 2009
Posted 2010-03-09 9:21 PM (#117401 - in reply to #117397)
Subject: RE: Sundowner Lite Trailers
I don't know about problem years, but I'm interested in knowing how to tell which Sundowner trailers are all aluminum and which are aluminum over steel frame. Thanks.
whitewood
Reg. Jun 2009
Posted 2010-03-09 10:39 PM (#117406 - in reply to #117397)
The way to know for sure-------------in the last 6 of the vin it needs to start with LA or AA all others are steel frame
jim bob
Reg. Jan 2008
Posted 2010-03-10 10:15 AM (#117412 - in reply to #117397)
The steel framed/alum.skin trailers were called Valuelites from late 97 until sometime in 2003, when all of Sundowner horse trailer models were named Sunlite with a model number following the word SUNLITE.  ALL steel framed trailers went out of Sundowners lineup in Dec. of 2007.  All Sundowner models have been aluminum framed since Jan. 2008.
 The Sunlite models that were steel framed were 707, 727, 728, 737, 777, 777SR, Stampede's, 747, or 767.  In other words, any model number that ends in a "7" was a steel framed trailer from 2003 thru 2007.
I might ad that, the main source of problems resulted in trailers in the midwest and northeast; in which trailers used in winter months with salt and chloride used on roads in this part of the country resulted in accelerated deterioration of the steel frames.  However, the majority of these trailers haven't been affected, and are still giving excellent service for their owners.
In the earlier post; the VIN number is a very simple way to tell; ALUMINUM is LA or AA followed by four numbers (last six of the VIN); and the STEEL framed models will be VA, VB, VC, VE, or HA and ZA in the case of steel framed living quarters.  Hope this clears up the confusion.
horsey1
Reg. Dec 2004
Posted 2010-03-10 10:27 AM (#117414 - in reply to #117412)
Originally written by jim bob on 2010-03-10 10:15 AM
Please be aware that this is an opinion from Jim Bob. Trailer repair shops located in other parts of the country that do not have salt are reporting the same types of issues. You should look carefully at each and every unit you are considering.
ponytammy
Posted 2010-03-10 11:49 AM (#117419 - in reply to #117414)
500100100252525
Thank you for the replies. This helps clear up the naming conventions used by Sundowner.
Safet
Reg. May 2009
Posted 2010-03-10 12:32 PM (#117421 - in reply to #117397)
Have there been any problems with the newer Sundowner's (aluminum frame/aluminum skin ones)?
kim huck
Reg. May 2010
Posted 2010-05-17 1:01 PM (#120280 - in reply to #117397)
If I understand correctly, a 1997 Sundowner Sunlite Aztec would be steel frame, aluminum skin?
Kim
jackbrat
Posted 2010-05-17 6:36 PM (#120291 - in reply to #117397)
500100
Kim, do you have the Vin# ?
diggerdoo
Reg. Oct 2009
Posted 2017-06-09 11:17 AM (#170029 - in reply to #117397)
Thank you!!
Steve-O
Reg. Mar 2016
Posted 2017-06-09 11:43 AM (#170030 - in reply to #117397)
Take a magnet with you when you go to look at it.   A magent will stick to steel and not aluminum.  You can check the structure under the trailer and under the nose to see what metal is used where.
