delicate question
Last activity 2010-02-04 9:57 AM
21 replies, 7973 views
sweetas
Reg. Dec 2009
Posted 2010-02-01 8:27 AM (#115993)
Subject: delicate question
Is that dissolving RV-type toilet paper really essential? What if I run out and use the regular kind?
calamityj
Reg. Jun 2005
Posted 2010-02-01 9:28 AM (#116001 - in reply to #115993)
Subject: RE: delicate question
500100252525
Yes. Use RV toilet paper!!!!!!!!!!! the regular paper we use in our houses does NOT BREAK DOWN and will clog up your holding tank. Trust me on this.... I ran out and used charmin and paid the consequences. We had to use a power washer to flush it out of the down pipe and the tank. What a mess. (Not to mentioned being cussed out for an hour and a half by my husband).
I am waiting for LQ conversions with bidets...ha
nobodyimportant
Reg. Jan 2010
Posted 2010-02-01 10:53 AM (#116004 - in reply to #115993)
Whenever possible, use the RV paper.  It can clog your tank and interfere with your tank gauges.  If you have used it, in the past, I would recommend dumping an 8lb bag on ice cubes down the toilet then adding a couple of gallons of water.  Then drive around for a little while and the ice will literally beat the s--- out of your tank.
randemtam
Reg. Jun 2007
Posted 2010-02-01 5:44 PM (#116018 - in reply to #115993)
10010010010025
If you use another form of toilet paper....don't use Charmin. We had a clog one time with it as well. Now we use Cottonell. It has not caused a problem for our tank yet and it's nicer on the bum than the RV stuff.
brendaclemens
Reg. Jan 2009
Posted 2010-02-01 6:14 PM (#116020 - in reply to #115993)
Use normal paper...just put it in a waste basket :)
Gone
Posted 2010-02-01 7:50 PM (#116024 - in reply to #115993)
10002525
I won't pay "20" bucks for wipe. We use Angel soft and we don't have clogging issues.
flyinghfarm
Posted 2010-02-01 8:08 PM (#116027 - in reply to #115993)
1000100100
We delicately put the paper in a trash sack, to help with getting debris on the tank interior, and also it is one way to save a little room in the tank on longer stays....
tom-tom
Reg. Feb 2008
Posted 2010-02-01 8:48 PM (#116032 - in reply to #115993)
100100100
Not risking using household stuff. Our first LQ trailer had a clogged tank on our first trip out.  Not Fun!  We use the Campa Chem brand from Wal-Mart $2.50 a pack.  Never had a clog with it.  The bag of ice works well too.  Just add it to your tank with a little water and hit the road.  Works well to break up any sludge build up in the tank.
IcePonyGoddess
Reg. Nov 2006
Posted 2010-02-01 8:52 PM (#116033 - in reply to #115993)
500100100252525
Most RV'ers use Scott's TP.
If you want to test your TP. Put a few squares in a glass jar, fill with water, shake...if the TP dissolves, it's safe it use. If not....don't use.
That's the test recommended by RV'ers. <;o]
Jaas
Reg. Mar 2009
Posted 2010-02-02 10:19 AM (#116047 - in reply to #115993)
That's what I use, Scott's single ply.
sweetas
Reg. Dec 2009
Posted 2010-02-02 12:57 PM (#116052 - in reply to #115993)
Ahhh, you guys are great. I'm still laughing at the ice beating the stuff off the walls of the tank....
sweetas
Reg. Dec 2009
Posted 2010-02-02 12:59 PM (#116053 - in reply to #115993)
Wanted to add - a good friend told me a "delicate" trick to keep from having to scrub the toilet so much. Lay an 'X' of toilet tissue over the bottom of the bowl before you do your business....TMI for some, I know, but it seems like it could be a good idea!We are looking forward to getting our LQ - only 3 more weeks!
farmbabe
Posted 2010-02-02 3:05 PM (#116056 - in reply to #115993)
1000500100100
We can't even use Charmin in the house toilets!
To Much Trouble
Reg. Dec 2009
Posted 2010-02-03 7:03 AM (#116076 - in reply to #116056)
    ROFLMAO...I love that yall have the guts to approach this topic...I have been wondering about this very subject..and now I have my answer....KUDOS to you all .....
Gone
Posted 2010-02-03 3:03 PM (#116100 - in reply to #116033)
10002525
Originally written by IcePonyGoddess on 2010-02-01 9:52 PM
Most RV'ers use Scott's TP. If you want to test your TP. Put a few squares in a glass jar, fill with water, shake...if the TP dissolves, it's safe it use. If not....don't use. That's the test recommended by RV'ers. <;o]
Neat idea, I am going to try that.
nobodyimportant
Reg. Jan 2010
Posted 2010-02-03 3:24 PM (#116102 - in reply to #115993)
Another option would be to add a tank flush kit like what a lot of RVer's do.  This is a high pressure sprayer installed in the tank that you just hook your hose up to.  It rotates around and cleans out the tank.  I  believe that most RV service places should be able to install one.  Have no idea how much though.
tom-tom
Reg. Feb 2008
Posted 2010-02-03 7:29 PM (#116114 - in reply to #115993)
100100100
I acutally bought a cleaning wand in the RV section at Wal-Mart.  It hooks to a hose.  Stick the cleaning wand down in the tank thru the toilet and turn on the hose.  Pressure washes the tank and if you have a walk-thru door you can run the hose thru the horse compartment and straight into the bathroom without  dragging the hose thru your LQ.
sweetas
Reg. Dec 2009
Posted 2010-02-03 9:08 PM (#116120 - in reply to #115993)
One lady (whose horse trailer we looked at) had one of those wands. Said she did that to keep her tank indicators working properly.
sweetas
Reg. Dec 2009
Posted 2010-02-04 7:49 AM (#116135 - in reply to #115993)
OK, here's another question along these lines:Is there any reason we can't dump the tanks into our own septic tank? We have 2, one for the house and one for the barn. The one in the barn is only lightly used - there's the cleanout/inspection port - we were wondering if we can dump there if we needed to and what sort of havoc we might wreak. Anyone done this?
Ncatanz
Reg. Jun 2008
Posted 2010-02-04 7:58 AM (#116136 - in reply to #115993)
We empty our LQ black and grey water into our septic tank for our kennels, works fine.
Posted 2010-02-04 8:09 AM (#116137 - in reply to #116135)
Originally written by sweetas on 2010-02-04 8:49 AM
We've been doing this for years. When we had our septic tank replaced, we had a 6" capped pipe installed on the top. This allows the tank to be pumped out without having to dig out access to the tank. It also is a very easy port to use when dumping the trailers' holding tanks.
headhunter
Reg. Oct 2004
Posted 2010-02-04 9:57 AM (#116139 - in reply to #115993)
50010010025
We were told most holding tank treatment chemicals will kill the necessary bacteria in a septic tank. I've started buying "green" chemicals that say they won't harm septic tanks. I usually dump on the way home from shows as my regular show spots have convenient RV dump sites on the way home or on the grounds, but I like knowing I can dump at home if I want to.
