ABS light on freightliner
Last activity 2010-01-26 6:59 AM
4 replies, 4966 views
calfroper
Reg. Oct 2009
Posted 2010-01-25 10:34 AM (#115678)
Subject: ABS light on freightliner
My ABS just came on, any ideas?
Posted 2010-01-25 12:29 PM (#115683 - in reply to #115678)
Subject: RE: ABS light on freightliner
 What model and what year is the truck? You'll need a scan tool to check any codes. Are they Wabco or Bendix brakes? Air brakes? Hydraulic brakes? May need to check the VSS Sensor on top of the rear differential, be sure it's plug in, check adjustment, etc. If it's air brakes, it may be oil on a wheel censor or one may be out of adjustment. Loose wheel bearing will make the light come on. Tire pressure correct all the way around? Driven in any standing water lately??? Are your backing plates still in place? Water splashing on the shoes making the shoes swell. This will throw the ABS for a loop until theres enough heat to evaporate the water. Is the truck under warranty, if so see your local Dealer.
Paracadista
Reg. Oct 2009
Posted 2010-01-25 5:11 PM (#115694 - in reply to #115678)
WELCOME TO THE ABS NIGHTMARE! I have never decided wether they are worth it or not, doesnt matter we have no choice, but they are a PITA.
BlazingCreekBar
Reg. Nov 2008
Posted 2010-01-25 7:20 PM (#115697 - in reply to #115678)
Check your brake fluid reservoir cap.  If is miss seated it will throw the ABS light on.
brushycreekranch
Reg. Jun 2006
Posted 2010-01-26 6:59 AM (#115711 - in reply to #115678)
500100100100100
Mine came on back in June 05 when I went down a steep winding mountain pass in CO with no trailer brakes on the LQ . After the brakes cooled down the Freightliner place just did a reset and everything has been fine since.
