length of C&C 3 horse trailer
Last activity 2010-01-21 11:45 AM
8 replies, 5344 views
reddun25
Reg. Sep 2007
Posted 2010-01-20 8:53 AM (#115492)
Subject: length of C&C 3 horse trailer
I have a 3 horse C&C trailer with 10' LQ. Anyone know the length or how I go about figuring that out? I thought I read on another post someone else has a 3H with 10' and they said it was 24ft on the wall. How long is the GN portion, another 6 ft? So the total length would be 30ft? Thanks!
robdnorm
Posted 2010-01-20 9:24 AM (#115496 - in reply to #115492)
Subject: RE: length of C&C 3 horse trailer
500
I had one just like what you are describing. It was 24 on the floor. I believe they consider the gooseneck to be 8ft.
reddun25
Reg. Sep 2007
Posted 2010-01-20 9:37 AM (#115497 - in reply to #115496)
Thank you very much!
pinkmouse
Reg. Jan 2009
Posted 2010-01-20 10:29 AM (#115499 - in reply to #115492)
"I have a 3 horse C&C trailer with 10' LQ"
Ummmm...not to state the obvious, but since you already have the trailer, can't you just measure it with a tape measure??
horsecamper
Posted 2010-01-20 1:28 PM (#115512 - in reply to #115492)
red, I second that your trailer, if the stall sizes are standard, is 24 foot on the deck.  Length of noses will vary by manufacturer, with many high end being 6 inches longer than some not high end.  I agree with an earlier poster that your C&C would probably have an 8 foot nose exterior dimension.
Marla
Reg. Mar 2008
Posted 2010-01-20 4:03 PM (#115522 - in reply to #115492)
500
A tape measure should give you a pretty accurate idea.
Marla
reddun25
Reg. Sep 2007
Posted 2010-01-21 11:43 AM (#115546 - in reply to #115499)
Originally written by pinkmouse on 2010-01-20 10:29 AM
Because I am at work and the trailer is at home and needed an answer quickly. But yes, if I was at home I would use a tape measure.
reddun25
Reg. Sep 2007
Posted 2010-01-21 11:43 AM (#115547 - in reply to #115512)
Originally written by horsecamper on 2010-01-20 1:28 PM
Thank you for your help!
reddun25
Reg. Sep 2007
Posted 2010-01-21 11:45 AM (#115548 - in reply to #115522)
Originally written by Marla on 2010-01-20 4:03 PM
A tape measure should give you a pretty accurate idea. Marla
Yes I agree....if I was at home. I needed an answer quickly. I am blonde..but I can usually figure out the obvious but thanks!
