after market door / trailer wash near Omaha
Last activity 2010-01-24 9:30 PM
4 replies, 4742 views
Lazy M
Reg. Feb 2005
Posted 2010-01-16 8:18 AM (#115339)
Subject: after market door / trailer wash near Omaha
Hi, in a previous thread there was discussion about the cost of adding a walk through door to the bulkhead wall.  I'm wanting to do this and the conversion company in my area has quoted me $600.00 for the door and 1 hour of labor to do this.  The doors being discussed in the earlier posting were in the $200.00 and $300.00 range.  Just so I'm comparing apples to apples, why are these doors so much cheaper?  Are the doors hollow or wood filled?  I was under the impression that I would need a solid aluminum door.   Second question, I will need to take my trailer to be acid washed in the spring and haven't done that before, does anyone know of a truck wash familiar with horse trailers in a 75- 100 mile radius of Omaha.  Thank you Joan
arrowfour
Reg. Jan 2010
Posted 2010-01-17 12:42 AM (#115366 - in reply to #115339)
Subject: RE: after market door / trailer wash near Omaha
I had a walk-thru door put in my previous trailer and it was around $900,aluminum and rubber matting to match wall. they had to rebrace the frame where the opening was cut. If not done, it would be cheaper but not done right. Can;t just cut a hole...Also, the door/frame was flush with the wall, no "rim" around it for horse to step on at the bottom.Get what you pay for. Good luck!
Tresvolte
Reg. Feb 2008
Posted 2010-01-18 10:04 AM (#115416 - in reply to #115339)
There is a Blue Beacon in York on I-80 at the Petro. Don't have any idea how far that is from you though. www.bluebeacon.com
klaas
Reg. Jan 2010
Posted 2010-01-20 1:06 PM (#115511 - in reply to #115339)
I have been looking for an aftermarket door with not much luck. I finally ordered one from Featherlite out of Ceresco, IA for $475.00. Our dealer shipped it for free since he had a trailer headed back to Nebraska. Otherwise freight was going to run $150 - $200. The best truck wash is in York, NE (Blue Beacon) there may be one in Council Bluffs or Millard as well. good luck. Hart has a good door with bullet hinges in the same price range.Good luck
Lazy M
Reg. Feb 2005
Posted 2010-01-24 9:30 PM (#115664 - in reply to #115511)
Thanks a lot for the advice!  Joan
