Batteries 1 or 2???
Last activity 2010-01-19 5:18 PM
15 replies, 6481 views
tralbos
Reg. May 2008
Posted 2010-01-12 8:50 PM (#115178)
Subject: Batteries 1 or 2???
Putting a LQ together myself... How long can a guy camp with only one battery or should I go with two? And another question, am looking at deep cycle marine NC-24 120min and NC-27 160min batteries. The measurements are different in the two so I need to decide what kind and a single or double setup before I build the battery shelf.  Thanks
Posted 2010-01-12 10:13 PM (#115180 - in reply to #115178)
Subject: RE: Batteries 1 or 2???
Depends on if you are going to camp by the week or weekend, and if you plan on using a furnace. A furnace fan can drain a battery fairly quickly.
Without a furnace, a weekender LQ will last on one battery for a weekend. If you plan on weekly trips, two batteries will be the minimum.
The larger the battery size, generally the larger the capacity will be. Check with competing brands for the largest numbers.
Posted 2010-01-13 12:47 AM (#115185 - in reply to #115178)
If you decide on two batteries, Consider very hard on two 6 volt in series vs two 12 volt in parallel.  The series connection doesn't have the self discharge issues between the batteries.
Ncatanz
Reg. Jun 2008
Posted 2010-01-13 6:23 AM (#115189 - in reply to #115178)
Just to reiterate what Gard said, I have also found that the blower fan on the furnace seems to eat batteries a lot. I can camp several days using just the pump and lights but once you start using the furnace the batteries seem to drain pretty fast. My trailer is a small 6ft LQ that is well insulated but the 2 batteries will only last about 2 nights at 30 degrees.
CTRider
Reg. Sep 2009
Posted 2010-01-13 7:57 AM (#115193 - in reply to #115178)
10010010025
I would go with 2 batteries. Its always better to have too much than too little. Also remember you can take a generator and recharge your batteries during the day.
Posted 2010-01-13 8:15 AM (#115197 - in reply to #115178)
Little more on batteries.... http://www.rversonline.org/04LOWBatteries.html
Best bang for the buck is the Trojan T-105 golf cart batteries -- if you have space for them. They are considerably taller, and won't fit in some compartments. 2 6s in series is better than 2 12V batteries. Longer life, more forgiving, will last twice as long. Cost in range of $125.00-$165.00.
Edited by retento 2010-01-13 9:33 AM
301duster
Reg. Jan 2009
Posted 2010-01-13 8:18 AM (#115198 - in reply to #115178)
2 are nice, but keep in mind if one shorts out it will take the other one down with it.  Cost of replacement is double most of the time.  I have had it both ways.  If you don't pull a lot in the winter I would definitely go with the one group 27 battery.  If you go a lot in cooler climate and are going to be running a heater I would look at 2.  I've had both and will say that 2 batteries will not last twice as long as one good one.  The 6 volt series thing may be worth a good look also and may be cheaper I don't know.  I just never liked the fact that one battery starts getting bad and you have a hard time figuring out which one it is ,so you end up replacing them both for peace of mind.
wyndancer
Reg. Apr 2007
Posted 2010-01-13 3:06 PM (#115231 - in reply to #115197)
Originally written by retento on 2010-01-13 8:15 AM
That right there is the ticket....of course it's what I run as well.
BlazingCreekBar
Reg. Nov 2008
Posted 2010-01-13 7:09 PM (#115252 - in reply to #115178)
I use 3 batteries.
2 type 24's (because type 27 won't fit in the box) and a type 27.  I use the standard dial RV battery selector and have the two type 24s on one selection and the type 27 on the other.  Of course I can run all three on the both selection but the 24's will drain the 27 down to the level of the 24s.  I have the 27 separated for two reasons.  First it is a direct feed for my electric jack.  I never want to worry about my jack not working.  And if in a pinch I can flip to it and run the house systems as needed.  I have never had any weekend dry camping issues and we seem to run the heat with blower quite often up here thru the spring and fall.  Most all of our camping is dry camping.  I do carry a generator for AC and morning coffee.  I have the Progressive dynamics converter with charge wizard add-on so when I run my generator I can boost the voltage to a 14V+ charge state while making morning coffee.
I think the best battery set up GC or 12v would include a solar charging system.  You then would not need a generator and could go green.
A couple decent links below:
http://www.ccis.com/home/mnemeth/12volt/12volt.htm
http://www.ccis.com/home/mnemeth/12volt/12volta.htm
http://www.progressivedyn.com/prod_details/charge_wizard.html
tralbos
Reg. May 2008
Posted 2010-01-13 8:07 PM (#115254 - in reply to #115178)
Thanks for all the replies... If I go with the two 6 volt setup can they be charged with a regular 12 volt charger and or charge with a converter that has a charger built in? I am looking at getting this charger Intelli Power Converter 45 Amp"Mighty Mini" The Compact All-In-One System 45amp...AC/DC Distribution Panel and Inteli-Power Converter with Charge Wizard®
http://www.bestconverter.com/4000-Series_c_138.html
wyndancer
Reg. Apr 2007
Posted 2010-01-13 10:02 PM (#115257 - in reply to #115252)
Originally written by BlazingCreekBar on 2010-01-13 7:09 PM
and could go green.
Go green?...yeah, I'll try to think about that as I pull 16k around at 10 mpg.
Posted 2010-01-14 12:47 AM (#115260 - in reply to #115254)
Originally written by tralbos on 2010-01-13 5:07 PM
The two six volt batteries in series is electrically identical to a single 12 volt battery.  So... the 12 volt charger will do fine (the batteries are in series to the charger)
PS ... The two batteries must be identical for proper charging and use.  Can't have a little battery in series with a big battery.  Or old worn out battery and a new battery.
Edited by hosspuller 2010-01-14 12:49 AM
horsecamper
Posted 2010-01-14 11:17 AM (#115268 - in reply to #115178)
trailbos, Definately go two batteries.  I have a small LQ but big fridge and I read at night.  I just barely make it on a long weekend (3 nights) with two 12 volt newer batteries.  My early warning in that the fridge shuts down.  Must be the fan because the fridge is switched over to propane.  If you don't have solar (I don') or if you are not carrying a small generator to recharge (I do now!), you will probably have one of those incidents where your battery runs low and one of your safety alarms, sensing no power, starts beeping and wakes you up in the middle of the night and then you have to get up and hit the kill switch, leaving you with no power and no operable safety sensors.  I'm thinking to go solar. Some of my friends can extended camp with out using a generator.  They have the 2 6 volt system and a newer solar panel.  I asked how big the panel was and they said around 18"by 36".
barry
Posted 2010-01-19 2:15 PM (#115460 - in reply to #115178)
Probably should be another post but since the battery folks are gathered here. Anyone run a CPAP breathing machine off of 12 V with a small inverter. Does it drain the batteries like a furnace fan? Any experiences would be appreciated.Barry
flyinghfarm
Posted 2010-01-19 3:47 PM (#115467 - in reply to #115178)
1000100100
Now this is something I can personally talk about!!! Hubby has a CPAP, with a 12v adapter to run off the 12v (think cigarette lighter) receptacle in the LQ by the TV.  We have 2 batteries, and it runs fine off that hookup (it doesn't have the humidifier part on during this type of hook up) and we have been gone 20 days or so hunting, running the builtin generator for coffee, microwave when we were at camp etc. but all off while we were gone riding/hunting,  Worked the whole time....have done this at least 4 different hunting seasons......if we pack in, a 12v battery with roll up solar charger goes, along with the CPAP.....he loves that thing about as much as he loves me!!!!   it does not drain the batteries anything like the furnace does....
Edited by flyinghfarm 2010-01-19 3:49 PM
Rich M.
Posted 2010-01-19 5:18 PM (#115469 - in reply to #115178)
Me too on the CPAP, works great on 12v
