Battery Charging unit replacement
Last activity 2010-01-09 1:21 PM
2 replies, 3689 views
bechack
Reg. Mar 2006
Posted 2010-01-07 6:02 PM (#115005)
Subject: Battery Charging unit replacement
OK, when replacing the charger in my LQ, do I need to replace with 30 amp or can I upgrade to 45 amp or would it really make a difference.
Posted 2010-01-07 9:53 PM (#115014 - in reply to #115005)
Subject: RE: Battery Charging unit replacement
You can upgrade with a larger unit. Unless you modify or add to your circuits, the total draw will be the same. The larger unit will work less hard at the original capacity, and will generate less heat, which helps to ensure its reliability. Also the newer units have a more regulated charging system for the LQ batteries. This allows a better battery maintenance and will increase their life spans.
bechack
Reg. Mar 2006
Posted 2010-01-09 1:21 PM (#115060 - in reply to #115005)
Perfect.  Thank you.
