Auxillary fuel tank on pick up
Last activity 2009-12-15 11:54 AM
4 replies, 4298 views
calfroper
Reg. Oct 2009
Posted 2009-12-14 2:20 PM (#114253)
Subject: Auxillary fuel tank on pick up
I've got a aux fuel tank that is gravity fed. I tried to put a inline filter on it between the aux. tank and the main truck tank, but know can't get it to flow quick enough to keep up with the truck.  Before I didn't have any problems with it keeping up, just thought it would be a good idea to have the fuel going through two filters.
Any advice is appreciated.
brew26
Reg. May 2009
Posted 2009-12-14 4:20 PM (#114260 - in reply to #114253)
Subject: RE: Auxillary fuel tank on pick up
Got get a pump and run it directly into your truck tank. I have one on our long box and our short box and it works great on both of them. Fills in under fifteen minutes. Only thing to watch out for is your fuel gauge doesn't move as fast as the fuel goes in. So when your on about 3/4 full shut the pump off or you'll start spilling.
Posted 2009-12-14 4:56 PM (#114262 - in reply to #114253)
You could also try a fuel line with a larger ID (inside dimension). This would allow you to use a less restrictive filter and still be able to gravity feed. Most nipples on the inline filters, drastically restrict the fuel flow from the original fuel line size; some by almost half. Being able to use a larger diameter line can compensate for this loss. On a pressurised system, mechanical or electric, this restrictive affect is not as noticeable.
Many auto parts stores and marinas stock fuel lines and filters of varying sizes.
Edited by gard 2009-12-14 4:59 PM
CTRider
Reg. Sep 2009
Posted 2009-12-15 8:10 AM (#114273 - in reply to #114253)
10010010025
Thought I would mention for anyone that hauls alot. We just bought a pre-owned truck that was equipped with an auxilary fuel tank and system called Trans Flow Trax II. Has a pump with a computer system and monitor that automatically transfers fuel into the main tank as you burn it and the screen tells you how much is in both and your total capacity. Truck fuel gauge works off of the total of both tanks. Really cool system. Its around $1000 upgrade depending on your size choice and model. Really good investment if you haul alot and plan on keeping your truck awhile. This truck is an 07 Dodge with the 5.9 engine. 32,000 miles. Belonged to an older couple that pulled a 5th wheel. Like new condition. I think we got a heck of a deal. Anyhow you can google Trax II, its a company in California. We love it.
hogtownboss
Posted 2009-12-15 11:54 AM (#114285 - in reply to #114253)
10001001001002525
Originally written by calfroper on 2009-12-14 2:20 PM
The only way to be able to run and inline filter between the aux tank and regular tank is, you will need to install an aftermarket ilft pump to your aux. tank otherwise it will not work because there is not enough pressure to push through the filter.  Your best bet is to put it back how you had it and if you are wanting more filteration install something like an AIRDOG or FASS system between the main tank and the engine.
