Water Stains On Ceiling. Help!
Last activity 2009-11-30 4:51 PM
2 replies, 4215 views
Kesta
Posted 2009-11-24 9:18 PM (#113601)
Subject: Water Stains On Ceiling. Help!
Any suggestions on what to use to cover water stains?  The ceiling material is the same as that used in RVs, so it has a slick surface.  I attempted to use Kilz, but it doesn't absorb.  It just slides around due to the slickness of the surface.
Posted 2009-11-24 10:22 PM (#113603 - in reply to #113601)
Subject: RE: Water Stains On Ceiling. Help!
You could try abrading the surface with a Scotch Brite before applying the Kilz
Roger
Reg. Feb 2005
Posted 2009-11-30 4:51 PM (#113765 - in reply to #113601)
 The ceiling is probably the paper backing type paneling, the only thing Ive had luck with is can spray paint for light touch up, may have to just be replaced.
