Is a tow pkg installed?
Last activity 2009-11-23 9:22 PM
8 replies, 5421 views
AppyRider
Posted 2009-11-17 3:34 AM (#113263)
Subject: Is a tow pkg installed?
Hi, I need to know how to tell if a truck has a tow package or not. I'm looking for used 1/2 ton with 5.3 to 5.7L engine, having the hitch and 7-pin plug doesn't mean it has the tow package. What all is considered part of the package as far as the radiator, brakes, cooler, etc? Info on the internet is conflicting or too generic, it will say "when properly equiped" - does that mean having a tow package, having a higher axle ratio, or adding weight dist hitch? I need to be able to look under the hood myself and know what to look for since owners and dealers aren't familiar with towing needs. Thank you for any help!!! Karla
Posted 2009-11-17 6:32 PM (#113307 - in reply to #113263)
Subject: RE: Is a tow pkg installed?
What brand of truck & model year are you considering?
If it's a GM product look in the glove box.  There is a label there with all the factory installed options.  Then you'll have to look up the "RPO" codes for that year to see what the tow package code was.
Spooler
Reg. Aug 2006
Posted 2009-11-17 9:11 PM (#113315 - in reply to #113263)
50025
Take the VIN number to the parts department at Ford and have a build sheet printed out. Then you will know for sure.
hogtownboss
Posted 2009-11-17 10:17 PM (#113319 - in reply to #113263)
10001001001002525
Originally written by AppyRider on 2009-11-17 3:34 AM
All really depends on the truck, most 1/2 tons I buy or sell have a reciever hitch and 7 way plug installed.  But when I raise the hood and look, most have a really small transmission cooler or no extra cooler at all even though the window sticker states "tow package".
An actual "factory installed" tow package should include a quaility reciever hitch, 7 way trailer plug, transmission cooler (on automatic truck) some will include an external oil cooler.  Also "most" 1/2 ton trucks with a tow package will have a LOWER geared rear axle.  Like most 1/2 ton Chevys will have either 3.08 or 3.42 gears on standard trucks and the tow package option will have something like 3.73 gears.
AppyRider
Posted 2009-11-18 1:49 AM (#113322 - in reply to #113263)
Thanks for the input on glove box label, and I'll see if Dodge dealer does the same thing with VIN #. I'm leaning towards Dodge Ram 5.7 truck. Is the radiator double or larger with tow pkg? - I'm thinking that would be something I could ask someone in a phone call before I waste gas going to look at their truck. And an axle ratio of 4.10 is a "lower" gearing than 3.73 or 3.55 not a higher? good to know. Thank You !!
Yvette
Reg. Jul 2006
Posted 2009-11-18 6:33 AM (#113331 - in reply to #113263)
100100100
If the vehicle manual is in the glove box it should have a page that explains the vin codes and you can match up the numbers and letters of whats on the truck and that will tell you exactly what it has.
hogtownboss
Posted 2009-11-18 2:54 PM (#113366 - in reply to #113322)
10001001001002525
Originally written by AppyRider on 2009-11-18 1:49 AM
That is correct, the higher number you go the lower the gear ratio is.  Now days the radiator may not change with a tow package like they did say back in the mid to late 80's and 90's.  Just take a 1994 Chevrolet 1/2 ton I just bought with a 350 engine and automatic transmission is just a base model package with small 2 core radiator and 3.42 gears, but I also have the same truck with a factory tow package and it has a 4 core radiator, trans cooler and 3.73 gears, much like the larger 3/4 tons trucks come with.
AppyRider
Posted 2009-11-19 3:49 AM (#113397 - in reply to #113263)
Wow! This is great info, Thanks!
Spooler
Reg. Aug 2006
Posted 2009-11-23 9:22 PM (#113548 - in reply to #113263)
50025
Yes, Dodge will do this for you. If the 1500 Hemi has 20' rims and tires it will have a 3.92 rear end. That's what mine had.
