Help if you can! Thanks!"/>
Finishing trim on DIY LQ Windows
Last activity 2009-10-17 11:59 AM
6 replies, 8183 views
flyin'horse
Reg. Sep 2009
Posted 2009-10-14 8:03 PM (#111871)
Subject: Finishing trim on DIY LQ Windows
I've searched the archives but can't get any real good info on how people are trimming out the windows in DIY LQ's.   I've insulated and am now ready to panel the interior.  The paneling does not meet the window frame fllush-ly (it's not a word, hope you now what I mean).  How is that gap to be filled?  I've studied photos of Toddredwrench's work and Macwall's but can't figure out what they're doing.  It's like I need something flexible to go around the curves of the window and fill that gap between the paneling and the window frame yet also come around and finish off the cut edge of the paneling.  I want to make sure that the screws that hold in the glass and the screen for the window are still accessible in case something breaks or needs to be replaced.  Does this make any sense?  45 Help if you can!  Thanks!
memory
Reg. Jul 2007
Posted 2009-10-15 6:06 PM (#111902 - in reply to #111871)
Subject: RE: Finishing trim on DIY LQ Windows
I was wondering the same things. Thanks for asking.
AQHA 123
Reg. Oct 2008
Posted 2009-10-16 2:56 PM (#111944 - in reply to #111871)
I did mine when I was doing the fir stripping. I built a light frame around the windows and door then I attached the tongue and grove paneling to that. What if you used some nice looking 5/8 inch rope to trim around the window? I used some of this in a few places on my LQ and it dresses it up nice.
Posted 2009-10-16 4:01 PM (#111952 - in reply to #111871)
Any hardwood of your choice, mitered at the corners and shaped to fit the windows, and edged with a router will form a very pleasing trim. It can be stained to match your interior, or a contrasting colour to add interest.
flyin'horse
Reg. Sep 2009
Posted 2009-10-17 11:26 AM (#111992 - in reply to #111944)
Thank you, I am considering the rope idea, I read about somebody else doing that also!
flyin'horse
Reg. Sep 2009
Posted 2009-10-17 11:32 AM (#111993 - in reply to #111952)
Thank you gard, you make it sound so easy!!  Can you come to my house and do it for me?? LOL  Maybe your'e referencing the same thing, but I'm actually talking about the gap that's created when the interior walls are made thicker by adding firring strips and paneling.  The windows are now recessed in the wall.  I'm not understanding how I could use a rigid piece of wood to follow the curve created by that gap.  Does anyone have any close up photos of what they've done?
Posted 2009-10-17 11:59 AM (#111994 - in reply to #111871)
Look at the windows in your house. The glass window panel is recessed into the wall, closer to the outside than the inside. There are some pieces of wood called jam extensions, that take up the gap between the window frame and the face trim on the inside wall. The extension curves of the trailer window corners, are simply cut from a board to the same radius as the present window opening, or their shape can be changed to suit your desires. The final trim is installed over the edge of the extensions, which are fitted flush with the interior wall surface you have already installed.
It sounds more complicated than it is. Just imagine the inside of your trailer wall being the same as the interior wall of your house. Instead of square corners, you are working with a radius. That's the only difference. You may elect to change your trim to square corners, which results in a quite acceptable appearance. It's your trailer, and you can finish it any way you please.
With the weather we're having now, I would like to be most places than here. You might have a deal. LOL
Edited by gard 2009-10-17 12:03 PM
