Poll tough trailer jack
Last activity 2009-10-10 1:58 PM
3 replies, 8446 views
cobbler
Posted 2009-10-10 12:39 PM (#111701)
Subject: tough trailer jack
Hoping you folks can help?  Seems the Bulldog trailer jack is getting quite tough to use now.  The wife can barely make it work with out a lot of sweating and I don't remember it being that tough to use last year . this is on a 2003 Exiss 4h Sport gooseneck.  Do we need to replace these jacks every few years?  Tried to grease it but there arn't any fittings Help please?  thank you,Cobbler
cobbler
Posted 2009-10-10 12:41 PM (#111702 - in reply to #111701)
Subject: RE: tough trailer jack
sorry, this was wanted to be a post, newbie here....and a slow learner too?....
Posted 2009-10-10 1:46 PM (#111703 - in reply to #111701)
Take the top cover off the jack itself, should be one or two little sheet metal screws holding the cover on. Pour a little engine motor oil on the screw/worm gear, put on your best cranking arm and twist away. The grease gets dry and stiff, the engine oil will loosen the grease and free up the gears.... That is if there's no stripped or gaulded parts. After it's free, use a yard stick, old piece of molding, a clean stick, etc. to smear some grease back onto the screw.... Spend a little extra coin on the lubricants, purchase synthetic oils and greases and you may never have to lube this jack screw again....
Posted 2009-10-10 1:58 PM (#111706 - in reply to #111701)
Hello Cobbler ... Welcome to this forum.
The trailer jack has two sets of moving parts.
The first is a pair of gears at the top.  They convert the horizontal rotary motion of your crank to a verticle rotation of a screw shaft.
The second is a nut on the vertical screw.
Lubricating the gears is easy. Lift the top cover of the jack and grease the gears. There may be a bolt securing the cover.
Lubrication the screw is a bit harder.  hitch the trailer on the truck.  (this will support the trailer) Look for a hole in the outer tube of the jack.  The inner tube will be blocking it.  Starting with the jack fully retracted, extend the jack leg while looking at the hole.  Eventually a hole in the inner jack tube will line up.  The foot tube inside the jack MAY obstruct the second hole.  You'll have to lower the foot too.  Squirt some heavy oil on the screw and extend and retract the jack a few times.
It should be easy again.
