Furnace didn't turn on
Last activity 2009-10-07 6:22 PM
7 replies, 4609 views
Sheryl
Posted 2009-10-07 10:26 AM (#111551)
Subject: Furnace didn't turn on
I wanted to test my furnace this weekend but was not where I could plug in to electric power.  I thought it would run off the battery and the propane.  It never would turn on.  It was working fine a couple of weeks ago when I tried it but I was plugged in then.  The cooktop and the water heater both worked on the propane so it wasn't empty.  Any thoughts?
Posted 2009-10-07 10:30 AM (#111553 - in reply to #111551)
Subject: RE: Furnace didn't turn on
Does the furnace have a 12 volt or 110 volt fan blower?
Sheryl
Posted 2009-10-07 11:20 AM (#111563 - in reply to #111551)
I don't know the answer to that.  How can I tell?
horsey1
Reg. Dec 2004
Posted 2009-10-07 12:30 PM (#111566 - in reply to #111551)
It will be 12V blower. All regular RV furnaces are.
CTRider
Reg. Sep 2009
Posted 2009-10-07 1:26 PM (#111568 - in reply to #111551)
10010010025
CTRider
Reg. Sep 2009
Posted 2009-10-07 1:37 PM (#111569 - in reply to #111551)
10010010025
We tried ours this weekend and in Texas it was still warm enough we had to set the thermostat on 90 to get it to ignite. Make sure your 12 volt master switch is on if you have one.
Posted 2009-10-07 5:11 PM (#111586 - in reply to #111551)
Is your battery charged and in good shape? Is it new or aged? If the furnace works on a/c and not the battery, I would suspect a low voltage battery problem. Was your battery switch on when you tried the furnace?
If your system doesn't have a volt meter, how bright are the interior lights when they are running off the battery? If they are dim, your battery may not have enough voltage to fire the furnace igniter.
This would be one thing to check.
BlazingCreekBar
Reg. Nov 2008
Posted 2009-10-07 6:22 PM (#111592 - in reply to #111551)
One of the best lil toys I purchased was a digital volt meter that you plug into your 12v cigarette lighter type receptacle generally located near the television area. I got mine at Wal-Mart in the marine area. With that and this chart, I am always aware of my 12v power supply. http://www.ccis.com/home/mnemeth/12volt/voltchart1.gif
