4star fuse help needed now
Last activity 2009-10-06 11:17 AM
5 replies, 5192 views
compactcd
Reg. Jun 2007
Posted 2009-10-03 8:05 PM (#111411)
Subject: 4star fuse help needed now
we are at a show and our trailer will not get jacked back up. we have no power in the living quarters area and we can.t get the electric jack to work. we can.t find the large fuse to see if that is why it wont work. where should we look for it help needed asap phone number is 253 381 3935 we
hogtownboss
Posted 2009-10-03 8:51 PM (#111415 - in reply to #111411)
Subject: RE: 4star fuse help needed now
10001001001002525
Originally written by compactcd on 2009-10-03 8:05 PM
The fuse on ours is located in the battery box.  Follow the wire from the jack and you should find it.  It might run into a junction box then to the batteries.
No since you have no power in the LQ either I would check the batteries.
Do you have any power with the truck plugged into the trailer?
compactcd
Reg. Jun 2007
Posted 2009-10-03 11:50 PM (#111424 - in reply to #111411)
no we have no power when it is pluggwd into the truck
hogtownboss
Posted 2009-10-05 10:38 AM (#111443 - in reply to #111424)
10001001001002525
Originally written by compactcd on 2009-10-03 11:50 PM
Hmmmm, Then I would trace the plug on the trailer to the juction box then to the batteries and you should fine a resetable breaker and see if it has been tripped.
laurie
Reg. Jun 2004
Posted 2009-10-05 2:37 PM (#111453 - in reply to #111411)
10010010010025
model and year of truck would be helpful.
My chevy has a large square fuse under hood for all trailer stuff. 40amp If I remember correctly.
Mira
Reg. Feb 2009
Posted 2009-10-06 11:17 AM (#111491 - in reply to #111411)
We've had that problem ended up having to get deep cycle batteries you should have a hand jack if all else fails ours does.Not fun when this happens.
