blocking or lifting a horse trailer that has torsion axels
Last activity 2009-10-30 10:28 AM
8 replies, 6365 views
crissy_cowgirl
Posted 2009-10-01 7:53 PM (#111331)
Subject: blocking or lifting a horse trailer that has torsion axels
anyone know how to lift of block a trailer that has torsion axels? i have a 6 horse hart with a small LQ's and full midtack so it has some length and i have had some trouble scraping in areas it shouldnt. i have to have it a little higher in the front in order for the plumbing not to get ripped out but then the back with scrape. any ideas?
Posted 2009-10-01 8:54 PM (#111332 - in reply to #111331)
Subject: RE: blocking or lifting a horse trailer that has torsion axels
The trailer dealers around here charge $500-$600 to block the axles on trailers.
check with your dealer, If there is a trailer manufacture ( Horse, Dump, or Utility trailer, any competant mfg should be able to do it)
They just  unbolt or cut the welds on you axles and add a spacer inbetween the frame and the axles.  The trick is to line the axles back up so they pull straight when they are reinstalled. If they do the job wrong, you'll eat tires like crazy.
hogtownboss
Posted 2009-10-01 9:42 PM (#111334 - in reply to #111331)
10001001001002525
Originally written by crissy_cowgirl on 2009-10-01 7:53 PM
Where are you located?  Most trailer dealers that has a full service department can more than likely handle the job.  If you are in the North Texas area I can give you a few names and numbers of places that does this all the time.
crissy_cowgirl
Posted 2009-10-02 6:46 AM (#111344 - in reply to #111331)
we are located in Gainesville ga.
hogtownboss
Posted 2009-10-02 11:17 AM (#111352 - in reply to #111344)
10001001001002525
Originally written by crissy_cowgirl on 2009-10-02 6:46 AM
I would start by going to the main page of this website, on the tabs just under the heading is a list of options.  Click on the tab listed dealer and click on your state and there is a list of dealers with phone numbers and addresses.  Maybe one of them is close to you.  I would try the ones that offer the large trailers first!
Hope this helps. HTB
RTSmith
Posted 2009-10-02 11:54 AM (#111356 - in reply to #111331)
Chrissy- Like HTB says, it is a fairly common item on many large trailers. We've done many over the years. Pricing will vary depending on how the axles are attached but the numbers you've seen here are pretty accurate. If you get to the stage that DIY is not an option, we don't look to be too far up the road. Please give Roger a call at 931-685-4040 and we'd be tickled to help.
RTSmith
www.SelectTrailer.com
millironk
Reg. Feb 2009
Posted 2009-10-29 10:39 PM (#112587 - in reply to #111331)
We are located in southeast Iowa. Anyone know of someone that lifts trailers around this area?
hogtownboss
Posted 2009-10-29 10:53 PM (#112588 - in reply to #111331)
10001001001002525
Go to the bar on the upper part of this page and click on dealers, then search for dealer by state.  I found there is 19 dealers in your state.  I am not sure if any are close or you can check the states next to you as well.  Most trailer dealer that offer service can do the job.
ClaudiaIN
Reg. Feb 2009
Posted 2009-10-30 10:28 AM (#112612 - in reply to #112588)
I'm going to look this up as suggested- we have been quoted $1,000
