Cleaning black streaks off white enamel siding
Last activity 2009-09-16 10:19 PM
3 replies, 6047 views
apex6000
Reg. May 2009
Posted 2009-09-14 3:51 PM (#110690)
Subject: Cleaning black streaks off white enamel siding
Anyone know of anything that will clean the black streaks off of aluminum white siding? The only way I've been able to get it off is using 3M polishing compound then a coat of wax. But 6 months later I'm right back to where I was. Any help would be appreciated..
Gone
Posted 2009-09-14 6:32 PM (#110694 - in reply to #110690)
Subject: RE: Cleaning black streaks off white enamel siding
10002525
Polishing compound might strip your paint off. I took the advice on here and used purple power. It worked beautifully. I hand waxed my trailer with a good grade car wax afterwards. Now, the streaks are faint/minimal to non existent. They come off with a soft brissel brush and a good car wash soap. If we have a hard rain and I see some faint streaks, I clean them right away.
Edited by Gone 2009-09-14 6:54 PM
hogtownboss
Posted 2009-09-14 10:31 PM (#110705 - in reply to #110690)
10001001001002525
Originally written by apex6000 on 2009-09-14 3:51 PM
Find gard, he can tell you of direct you to who can help you.  The aluminum top rail is what's causing the black streaks.  Lucky for us, our top and corner rails are painted white!  My 2000 Exiss was bad about this until I ACID was it, the problem solved until the next year.
One of the other guys should stop by shortly that knows what to do the right way!
HTB
crowleysridgegirl
Reg. Apr 2005
Posted 2009-09-16 10:19 PM (#110778 - in reply to #110690)
2000500100
I've always used Streakmaster's Black Streak Remover with good results.
