Trailer axles
Last activity 2009-09-11 12:09 PM
4 replies, 3780 views
Karen J
Reg. Sep 2009
Posted 2009-09-10 10:08 AM (#110539)
Subject: Trailer axles
I have a 1992 4 horse valley stock trailer and was wondering if anyone knew where I might be able to get replacement axles for it. I live in NY state. Thanks
Posted 2009-09-10 12:32 PM (#110554 - in reply to #110539)
Subject: RE: Trailer axles
Hello Karen .. Welcome to the forum.  Why do you need axles?  Most axles can be repaired by replacing a few parts.   Otherwise, an auto repairer can order you any axle you might want.
Karen J
Reg. Sep 2009
Posted 2009-09-10 4:02 PM (#110562 - in reply to #110539)
One of the axles was replaced by a previous owner. It was too small and when used bent. So I figured since this is an older trailer it might be safer to replace. But I am not a professional repair person and I could be wrong. Any advise would be greatly appreciated. Thanks again.
jim bob
Reg. Jan 2008
Posted 2009-09-11 10:27 AM (#110583 - in reply to #110539)
Find a trailer dealer in your area that has a parts and service facility.  They will be able to either repair what you have; or if in fact the axle is bent; they will be able to get you a replacement or maybe a heavier axle.
Posted 2009-09-11 12:09 PM (#110585 - in reply to #110562)
Originally written by Karen J on 2009-09-10 1:02 PM
You might want to get the trailer to a competent trailer shop as suggested by Jim Bob.  Be aware that trailer axles routinely are MADE with a bend in them to provide the proper tire camber.  Without the proper camber(tire angle from vertical) the tire wears prematurely.
