trailer roof
Last activity 2009-09-01 10:43 AM
8 replies, 7953 views
illini
Reg. Mar 2009
Posted 2009-08-30 6:34 PM (#110128)
Subject: trailer roof
Need help finding polyurethane caulk. I read on here that it's the best for fixing seams on trailer roofs. We just can't find it. Where do you suggest to look? Also what colors we also wanted silver/gray. Home Depot,did not have it. Also what price does a tube usually run?
Thanks
Posted 2009-08-31 8:11 AM (#110141 - in reply to #110128)
Subject: RE: trailer roof
You can find the marine caulking here:
http://www.jamestowndistributors.com/userportal/search_subCategory.do?categoryName=Caulking&categoryId=32&refine=1&page=GRID
These are the ones I use
http://www.jamestowndistributors.com/userportal/show_product.do?pid=2002&familyName=3M+5200+Marine+Adhesive+Sealant
http://www.jamestowndistributors.com/userportal/show_product.do?pid=3514&familyName=Sikaflex+295UV
http://www.jamestowndistributors.com/userportal/show_product.do?pid=1536&familyName=BoatLife+Lifeseal
Posted 2009-08-31 4:36 PM (#110163 - in reply to #110128)
You might try one of the roofing supply companies in your area.  Googling your area (arenzville il) and "roofing supply" got 1/2 dozen hits.
hogtownboss
Posted 2009-08-31 5:09 PM (#110165 - in reply to #110128)
10001001001002525
Don't mean to step on any toe's here. But a few years back we had a 2000 Exiss we could not keep the seams sealed so after 2 or 3 tries I went to Home Depot and bought white roof cool seal for mobile homes and a large brush. Cleaned the top with sopa and water, let it dry over night, then painted the complete top seams and everything with the cool seal and that did the trick. Even cooled down the horse compartment a bit in the summer. Might not be the correct way, but it was cheap and worked!
HTB
Posted 2009-08-31 9:27 PM (#110176 - in reply to #110165)
Originally written by hogtownboss on 2009-08-31 6:09 PM
 I went to Home Depot and bought white roof cool seal for mobile homes and a large brush. Cleaned the top with sopa and water, let it dry over night, then painted the complete top seams and everything with the cool seal and that did the trick.  Might not be the correct way, but it was cheap and worked! HTB
I tried that product on a steel restoration. Sanded the whole roof, put down a converter, acid primer and the Cool Seal. At the end of the first trip it was starting to peel. I ended up sanding it all off and spray painted the roof with a marine polyurethane paint, that still looked like new several years later. I'll not again, waste my time with Cool Seal.
If you want a rubberized roof, use an elastomeric product. It will absolutely seal the roof, stay flexible and is long lasting.
Edited by gard 2009-08-31 9:30 PM
Winny
Reg. Sep 2009
Posted 2009-09-01 7:44 AM (#110184 - in reply to #110176)
Gard.....could you please tell me the brand name of the elastomeric product that you recommend and where it can be purchased?  We are going to reseal our trailer roof and would like to use a product that will work well.  Thank you....
Posted 2009-09-01 8:33 AM (#110186 - in reply to #110184)
There are many manufactuers; here are a few:
http://www.fixallroofs.com/roof_coatings/elastomeric_roof_coatings.html
http://www.hytechsales.com/prod2150.html
http://www.jnkproducts.com/liquid-roof.htm
http://www.pplmotorhomes.com/parts/rv-roofs/elastomeric-roof-coating.htm
http://www.thefind.com/garden/info-elastomeric-roof-coating
traveller
Reg. Jun 2005
Posted 2009-09-01 10:36 AM (#110189 - in reply to #110128)
I just spent the weekend painting the elastomeric on top of my LQ gooseneck.  I purchased it at Home Depot.  I scrubbed the top with Streak Master Ultra Guard, caulked some areas with a caulking I purchased at a RV center, can't remember the name, acid washed the top with the Streak Master Aluminum Brightener, and finally put two coats of the elastomeric paint.  I think it looks pretty good, hoping that it works.  It was recommended to me to do the acid wash to etch the aluminum roof, I was a little nervous about it since the sides of my trailer is painted aluminum, but I rinsed it well and got down on the ground and rinsed the sides well so the aluminum brightener was cleaned off.  I don't know it I did a good enough job washing the top with the acid wash, but it appears to have made a good bond.
traveller
Reg. Jun 2005
Posted 2009-09-01 10:43 AM (#110190 - in reply to #110128)
The caulking that I purchased was soft and sticky.  It was white which was fine since the top was painted white.  The RV center recommended that particular product, it cost about $8 a tube.  I looked at Home Depot but wasn't sure their products were exactly what I wanted.  The marine caulking material may be even better.
