Cinch
Last activity 2009-09-20 11:34 AM
12 replies, 6960 views
Nicki
Posted 2009-08-17 10:00 AM (#109479)
Subject: Cinch
I am shopping for a new cinch and would like to know your opinions.  I have a Professional Choice neoprene roper style and it has always worked well in the past.  I have since bought a new horse that gets sore every time I use it.  I was thinking of buying the mohair roper style cinch, but I was concerned about the buckles.
Thank you for your opinions
dawnb
Posted 2009-08-17 11:35 AM (#109484 - in reply to #109479)
Subject: RE: Cinch
Could you explain more about what it is with the buckles that you want to know.
hogtownboss
Posted 2009-08-17 12:01 PM (#109486 - in reply to #109479)
Subject: RE: Cinch
10001001001002525
Originally written by Nicki on 2009-08-17 10:00 AM
What part is getting sores? around the buckles, under the bottom?
You might check other things first, make sure your cinch is clean, make sure the buckles is not rubbing, maybe cinched to tight or too lose, etc!!  We have used the PC brand neo cinch for years with NO issues at all.  On my paint mare everybody at the roping pen was talking about how I needed to use a mohair cinch blah, blah blah, so I bought one, used it 1 time and sold it!  Horse hated it she would not work for me and made her sore.
About the buckles, they are the SAME!  You can buy them with the old style or the newer roller buckles.
lesliemal
Reg. Sep 2007
Posted 2009-08-17 12:23 PM (#109491 - in reply to #109479)
Subject: RE: Cinch
I have a horse that seems to gall easily in the girth area.  I have used the Classic Equine Soft Touch Cinch with good results and just recently have used a cinch with the hospital felt against the horse with good results as well.  I also make sure I stretch my horse's front legs after cinching up to be sure no excess skin is under the girth. Having said that, the galling on my horse had nothing to do with buckles but the material against his skin.
Nicki
Posted 2009-08-17 2:38 PM (#109501 - in reply to #109484)
Subject: RE: Cinch
On the neoprene cinch the neoprene goes under the buckles.  On a rope cinch there is nothing under the buckle.  I would think the buckle on the rope cinch would dig into the horse.
Nicki
Posted 2009-08-17 2:41 PM (#109502 - in reply to #109486)
Subject: RE: Cinch
She is getting sore just behind her leg.  I do stretch her out, but after we ride up and down some steep hills the cinch seems to crawl right bach up against her leg.
lesliemal
Reg. Sep 2007
Posted 2009-08-17 3:13 PM (#109505 - in reply to #109479)
Subject: RE: Cinch
Just behind the leg is also where my horse would get galled/raw.  Try that Soft Touch cinch. It worked well for us. I have used both the roper style and the straight style. It is really smooth and soft.  Also does your saddle have different rigging options?  If so, you might could alter your current rigging position and see if that helps.
Marla
Reg. Mar 2008
Posted 2009-08-17 8:25 PM (#109525 - in reply to #109479)
Subject: RE: Cinch
500
Put a sheepskin cover on your cinch and that should solve the problem.
Marla
Ike
Reg. Jun 2005
Posted 2009-08-21 9:54 AM (#109767 - in reply to #109479)
Subject: RE: Cinch
I am using the Pro Choice SMx Neoprene Western cinch and like it much better than the mohair ropers that came with my saddles. I have the ropers hanging in the tack room....maybe I'll sell them at the next trail ride.
As suggested above maybe you can rig the cinch diff on your saddle or maybe you have the saddle too far up on her withers. check you saddle position and rigging.
I've had better luck with the neoprene and I see some new and improved ones that breath more for sale now too!
Nicki
Posted 2009-08-24 11:29 AM (#109903 - in reply to #109479)
Subject: RE: Cinch
We do some pretty steep up and down climbs and my saddle will move back and forth.  The cinch seems to end up right on the leg pit.
My saddle does fit my horse.
Flyin J
Reg. Sep 2009
Posted 2009-09-18 1:50 PM (#110841 - in reply to #109479)
Subject: RE: Cinch
Check with young Sam Harper at The Little Humboldt Ranch in Nevada.  He makes some beautiful mohair cinches.  See the article on his work at:
 http://quarterhorsenews.com/index.php?option=com_content&task=view&id=2031&Itemid=58
Help this talented young man out.  I've got one ordered from him now.  He'll make it up however you want it.
rodear
Reg. Jun 2005
Posted 2009-09-18 3:04 PM (#110843 - in reply to #109479)
Subject: RE: Cinch
If your saddle is slipping back and forth on the hills then it isn't on tight enough.  When going down those steep down hills and the saddle slips forward, so does the cinch, ends up behind the legs and galls your horse.  You might stop at the top of a steep climb and tighten your cinch before going down, making sure the cinch is not making contact with the legs or that the skin is folded under.  I have found that if I tighten the rear cinch snug, the saddle tends to stay back better on those steep down hills.  Some horses or mules are so mutton withered that a croupper or breeching is needed to keep the saddle back.  Sometimes just setting your rigging up so the front cinch is closer to the 3/4 position than the full position is all that is required.
longearsrule
Reg. Apr 2006
Posted 2009-09-20 11:34 AM (#110880 - in reply to #109479)
Subject: RE: Cinch
100100100
You might also try to cross fire the girth. That pulls it back also if you don't have a way to change the rigging. I have done that on my mule.
