Featherlite trailer question(s)
Last activity 2009-08-13 9:35 AM
6 replies, 6375 views
Safet
Reg. May 2009
Posted 2009-08-07 7:58 PM (#109142)
Subject: Featherlite trailer question(s)
I'm looking at a Featherlite, manufacture date is 2000, but I believe the trailer date is 2001.
Was this a good manufacture time for Featherlite?  I'm not sure what the model number is, but it's a four horse with weekender living quarters and rear tack.  There's stainless steel cladding on the sides and nose.
Thanks!
301duster
Reg. Jan 2009
Posted 2009-08-07 9:22 PM (#109146 - in reply to #109142)
Subject: RE: Featherlite trailer question(s)
Have had a 96 and 99, nothing newer.  Good trailers no problems, both had full LQ.
genebob
Reg. Nov 2007
Posted 2009-08-08 8:47 AM (#109160 - in reply to #109142)
We had an 02' model 8541. Was a good solid trailer and wouldn't hesitate to buy another Featherlite.
Undertheguns
Reg. Jun 2008
Posted 2009-08-10 7:15 PM (#109232 - in reply to #109142)
I have a 2000 3 horse with a weekender package. Best trailer I've owned. Several friends have offered to buy it from me unsolicited.
brew26
Reg. May 2009
Posted 2009-08-11 8:40 AM (#109257 - in reply to #109142)
We had a 97 with a weekender that we figured almost had 250 miles on it before we traded it off...it went to every roping,rodeo or any where we took our horses because it we only had 1 other trailer at the time. We now have a 05 with a full lq in it that is also outstanding.
I don't think that the year or the model matters all the trailers are of oustanding quality.
DocBar
Reg. Jun 2009
Posted 2009-08-12 8:57 PM (#109337 - in reply to #109142)
My experience has been overall good with Featherlight. But check the frame beams I had a crack in mine right under where the horses back feet go, and had to have it repaired. Also, if ever you need an replacement axle,from rust out, it is more to replace then a steel trailer where it can be welded on. Because of aluminum construction, the axle must be welded to steel plates then bolted to the trailer.
Edited by DocBar 2009-08-12 8:58 PM
301duster
Reg. Jan 2009
Posted 2009-08-13 9:35 AM (#109351 - in reply to #109142)
FYI both of my Featherlites had bolt on axles, as I raised one of them myself and I wouldn't have done it if I would have had to torch and grind the axles off.  I've done the torch and grind axle replacement and it's no fun no matter how much beer you have on hand!!!!!!!!!!!!
