Why is it so hard to find replacement lights
Last activity 2009-08-09 8:33 PM
14 replies, 6505 views
playit7x
Reg. Aug 2009
Posted 2009-08-05 4:05 PM (#109018)
Subject: Why is it so hard to find replacement lights
I have a Hawk Classic 2007 trailer. Several of the running lights on top are not working, 2 on the sides are not working. I have searched the internet, trailer supply stores locally, farm equipment stores locally and no one has this particular light.
I called the place where I purchased the trailer which is a bit over an hours drive....she wants $11/light...plus shipping??? That seems high to me.
They are 3and15/16" long x a bit over an 1". Some are amber, 2 are 1/2 amber 1/2 red and some are solid red. They are sealed and have 2 prongs in the center. Hawk doesn't have a parts site I have to contact a Hawk dealer and none are close to me.
Cant a girl just find this type light somewhere............. 16
Posted 2009-08-05 4:37 PM (#109019 - in reply to #109018)
Subject: RE: Why is it so hard to find replacement lights
Are they LED's or incandescant..? Light may be OK, it may be a grounding issue with the fixture. Try swapping some of them around, try the sealed lamp in another fixture. Or test them with a 12 volt battery, a couple wires and a fuse....  If they are in fact bad, take it to the nearest truck stop, they have about any and every clearance light under the sun. If all else fails, contact Hawk direct, give them your serial number, a credit card number and watch for the UPS man in a couple days....?
http://www.hawktrailers.com/contact.asp
playit7x
Reg. Aug 2009
Posted 2009-08-05 5:00 PM (#109021 - in reply to #109018)
Thanks so very much. I will try all of your suggestions :)
Lisa
wyndancer
Reg. Apr 2007
Posted 2009-08-05 5:19 PM (#109022 - in reply to #109019)
Originally written by retento on 2009-08-05 4:37 PM
Right there is my biggest complain in horse trailers.
I'm working on a new one. All the outside markers stop/turn/tail are LED's. The clearance lights are LED's as well....do they run a separate ground wire? Ah, no...they ground to the body with a crimp on ring terminal. Has outside halogen floods...separate ground wire? Ah, no....crimp on ring terminal. Porch lights...the clip the ground wire off, grounds with the mounting screw.
giddyupmatt
Reg. Jul 2007
Posted 2009-08-05 6:20 PM (#109027 - in reply to #109018)
I have been able to get all mine from Carquest Auto Parts.
If you don't have one of those in your hood you might give these folks a try.
Poke here:  http://www.redneck-trailer.com/2009/J.htm
HappyTrailsTralers
Reg. Oct 2008
Posted 2009-08-05 6:45 PM (#109028 - in reply to #109018)
Hello - you can get the LED lights at Tractor Supply / Auto Zone and probably even WalMart - other wise give me a call 864 977 8009
If you remove the red or amber part of a light you will see a flat metal ground plate, usually if you tighten the ground screw the issue will be solved.
A few times I have found that if a ground goes the LED blows, check and see.
Risa
www.happytrailstrailers.com
BlazingCreekBar
Reg. Nov 2008
Posted 2009-08-05 7:27 PM (#109029 - in reply to #109018)
My favorite EBAY store...http://motors.shop.ebay.com/merchant/randpcarriages_W0QQ_nkwZQQ_armrsZ1QQ_fromZQQ_ipgZ25
laurie
Reg. Jun 2004
Posted 2009-08-05 9:11 PM (#109032 - in reply to #109018)
10010010010025
11.00 a light sound cheap and you won't be wasting your time and gas driving around. You don't get much for 11.00 any more. A small piece of trim on my truck was 60.00 LOL
hogtownboss
Posted 2009-08-05 9:48 PM (#109035 - in reply to #109018)
10001001001002525
I am replacing all of mine to the new clear lens LED's. Buying them off ebay.com in the ebay motors, car/truck prts section. like 5 or 6 bucks each or they will make a package deal like mine and I bought 10 clear/ambar LED's and 10 clear/red LED's for under 100. shipped to me.
Posted 2009-08-06 5:00 AM (#109045 - in reply to #109018)
Check out this page on the "redneck" site....  http://www.redneck-trailer.com/2009/J/J12-J16-J19.pdf
Tresvolte
Reg. Feb 2008
Posted 2009-08-06 7:25 AM (#109048 - in reply to #109018)
Probably a "Made in the USA" light instead of a chinese knockoff.
crowleysridgegirl
Reg. Apr 2005
Posted 2009-08-06 10:03 PM (#109101 - in reply to #109032)
2000500100
Originally written by laurie on 2009-08-05 9:11 PM
Really?
We bought the same lights (lens with 2 prongs) for $4 each at Tractor Supply.
Try Redneck suppliers in springfield,MO (ditto on Rentento's post.)
Edited by crowleysridgegirl 2009-08-06 10:04 PM
Dunoir
Posted 2009-08-07 6:40 AM (#109105 - in reply to #109018)
50010025
last year when selling my 10 year old BP, the lights stopped working.  I replaced the bulbs, still didn't work.  I asked around on here, got several suggestions and what worked was sanding the contacts - I even put the old bulbs back in and gave the new owner the replacement bulbs.
playit7x
Reg. Aug 2009
Posted 2009-08-09 3:43 PM (#109180 - in reply to #109018)
I want to thank everyone for all the help!!! What a wonderful site :)
I did a couple of things, I took the non functional lights off and put them on functional site and they all worked!! Aha clue #1
I called Hawk they said take a 1/4" ratchet and tighten ground screw on all.
When I did this all bulb sites worked and all lights were functional.....
So.... yes indeed it was a grounding issue not even the bulbs!!!
Seems like an issue that many have wonder why they don't change the design????
BTW,,, I looked at Tractor Supply, Big R, Rural King etc no one had these style lights????
Thanks everyone for your support
Lisa
daisycake123
Posted 2009-08-09 8:33 PM (#109195 - in reply to #109018)
We have a book from Peterson lighting any good parts store should be able look up that light we do it all the time if you post it someone should be able to find it for you and at least give you a number to order it by.
