Wiring
Last activity 2009-08-03 10:59 AM
1 replies, 3777 views
jackcu
Reg. Aug 2009
Posted 2009-08-03 9:59 AM (#108901)
Subject: Wiring
 have a standard 2 horse  cm bumper pull. It has a battery to operate the breakaway switch. My question is this. When the trailer is connected to my truck is the little battery being charged by my truck. If so then what wire from the truck is used to charge this battery, and what color is this wire normally?
Posted 2009-08-03 10:59 AM (#108903 - in reply to #108901)
Subject: RE: Wiring
quote:...  My question is this. When the trailer is connected to my truck is the little battery being charged by my truck.
Probably not..... If your trailer has one of these installed, it's getting a charge.... http://www.etrailer.com/pc-BAK~20400.htm
quote:.... If so then what wire from the truck is used to charge this battery, and what color is this wire normally?
Use this chart to figure out what wire would be correct for your vehicle/connector. Use a test light or volt meter to search for you correct wire.
http://www.horsetrailerworld.com/home/wiring.asp
