What kind of light is this?
Last activity 2009-08-02 8:46 PM
5 replies, 4389 views
Sheryl
Posted 2009-08-02 3:52 PM (#108862)
Subject: What kind of light is this?
Attached is a pic of a light in my trailer.  One is burned out and I cannot find out where to get more.  I think this must be an all in one unit because I can't find anyway to get the bulb out.  Camping World did not have them and my local dealer doesn't either.  Does anyone know about these types of lights?
Edited by Sheryl 2009-08-02 4:15 PM
Paints
Posted 2009-08-02 5:07 PM (#108865 - in reply to #108862)
Subject: RE: What kind of light is this?
Halogen recessed.Try to turn or screw it out- light taking light bulb outa socket.
lesliemal
Reg. Sep 2007
Posted 2009-08-02 5:19 PM (#108867 - in reply to #108862)
Who did your LQ conversion?  You might could get a replacement from them directly.  How old is the light?  When I purchased my trailer new, one of the lights was not working...the bulb was just loose.  Removed cover and took bulb out and reinstalled.  Be careful with the bulb as they are sensitive to the oil from your hands (at least that is what I was told). The folks at the dealership took care of mine before I left the lot with the trailer.
HWBar
Reg. Nov 2005
Posted 2009-08-02 7:51 PM (#108874 - in reply to #108862)
1000100100252525
Paints is right it's a halogen light and to change the bulb you need to twist the trim about 1/8th of a turn and then it will uncover the bulb underneath. The outside trim that you can see is all one piece just give it a slight twist.
Sheryl
Posted 2009-08-02 8:04 PM (#108875 - in reply to #108862)
Thank you. I will try to twist it out next time I'm at the barn!
Posted 2009-08-02 8:46 PM (#108880 - in reply to #108862)
You can get a replacement bulb from any big box hardware store.  Remember to avoid touching the new bulb with bare hands.  Use a thin cotton glove or a rag to hold it.  The oil from your skin will cause a "hot" spot and premature bulb failure.
