Fresh water tank ?
Last activity 2009-07-27 10:43 AM
2 replies, 3626 views
sidelock
Posted 2009-07-26 7:34 PM (#108570)
Subject: Fresh water tank ?
I just received my 30 gal. fresh water tank from Randpcarrages an ebay store that I paid an unbelievable  $48.88 for. The drain fitting is about an inch above the bottom because of the overall ring diameter of the fitting. How do you comlpetely drain the tank without leaving any water in it when the trailer is in storage for the winter ? I am thinking I would have to pump the last litlle bit below the drain hole   out somehow.
Edited by sidelock 2009-07-26 7:40 PM
MSM
Reg. Jun 2009
Posted 2009-07-26 7:47 PM (#108571 - in reply to #108570)
Subject: RE: Fresh water tank ?
You can either shim the tank on the opposite side of the drain and/or install a drain in the bottom of the tank and put a plug in the drain fitting located on the side of the tank.
Posted 2009-07-27 10:43 AM (#108594 - in reply to #108570)
If you purge your system with anti freeze in the fall, the little remaining water is a moot point. It will be flushed and replaced in the Spring. If you don't drain it, the remaining water will not harm your tank when it freezes.
It is very difficult to add ports to a polypropylene water tank. If it is of an ABS construction, drain valves and most other plumbing fittings are easily attached and modified.
