Ac on horse trailer
Last activity 2009-07-14 6:11 PM
6 replies, 8154 views
craig12
Reg. Jul 2009
Posted 2009-07-10 12:08 PM (#107805)
Subject: Ac on horse trailer
I have a featherlite with LQ, just no ac- thinking about mounting an ac unit to the front of the trailer? any ideas? Do not want a roof mount do to height.  Have a shed for trailer and it will not accomodate any more height.
MSM
Reg. Jun 2009
Posted 2009-07-10 12:25 PM (#107809 - in reply to #107805)
Subject: RE: Ac on horse trailer
Im not aware of any AC unit that could be mounted on a trailer that is reasonably that doesn't mount on the roof.  If you do find one will you have to pull it off and reinstall it everytime you setup camp?  Most horse trailers have a AC mount in the roof.  It might be easier to just install a roof mount and raise your roof on your shed?
memory
Reg. Jul 2007
Posted 2009-07-10 12:32 PM (#107811 - in reply to #107805)
They have portable air conditioners that you just put in in the corner or the living quarters and  run an exhaust hose out an opening.
Terri
Posted 2009-07-11 5:25 PM (#107862 - in reply to #107811)
200050010010010025
My trailer isn't very well insulated, but I tried one of the portable AC's and it didn't do anything to help with the TX heat.  I just broke down and bought a roof top unit.
Christian Cowgirl
Reg. Jul 2009
Posted 2009-07-14 1:28 PM (#108012 - in reply to #107805)
we are installing our underneath the tongue. It's gonna save us $400-600. Yes, you do have to make sure it is well retained and secured, and make sure it won't get in the way of your truck, but other than that I think it will work great.
Pmoore
Reg. Jul 2008
Posted 2009-07-14 6:07 PM (#108027 - in reply to #107805)
Lots of people have just regular room window unit ac mounted in the front of their gooseneck horse trailers and they work well. Probably require some extra bracing and cutting  hole in the front of the trailer under the gooseneck, but the back end sticks out just like in a window.
Posted 2009-07-14 6:11 PM (#108029 - in reply to #107805)
Build a bracket similar to this battery box to support your "window unit".
http://www.statewidealum.com/tc_27a.htm
