Electrical issue from cracked socket
Last activity 2009-07-05 6:09 PM
1 replies, 3518 views
laurie
Reg. Jun 2004
Posted 2009-07-05 4:25 PM (#107557)
Subject: Electrical issue from cracked socket
10010010010025
I got a new to me slightly used living qtr this weekend. When I went to hook up the lights the socket was cracked and the 6 prong hookup had turned so it didn't line up to the proper hookup. I blew several fuses in the truck which I replaced and now all outside lights are working. My problem is the lights on the inside won't work with out electricity. I checked the fuses and brakers which all looked good. Any ideas?
Posted 2009-07-05 6:09 PM (#107563 - in reply to #107557)
Subject: RE: Electrical issue from cracked socket
(Quote).... My problem is the lights on the inside won't work with out electricity.....
Neither do mine.... See if these two links give you any clues to what's going on/wrong.
 http://www.horsetrailerworld.com/home/wiring.asp
http://www.mrtrailer.com/hosspuller.htm
Edited by retento 2009-07-05 6:13 PM
