Trailer shaking
Last activity 2009-07-05 7:51 PM
10 replies, 6597 views
paint16h
Reg. Jul 2009
Posted 2009-07-04 6:12 PM (#107523)
Subject: Trailer shaking
Hello
I bought a used 4 star two horse slant BP 1995. I hauled my horses and the trailer rocks/shakes side to side. This happens  even when I am not moving. It's not the horses moving around....
Help?
Renee
Posted 2009-07-04 6:41 PM (#107526 - in reply to #107523)
Subject: RE: Trailer shaking
Originally written by paint16h on 2009-07-04 7:12 PM
Hello
Help?
Renee
paint16h
Reg. Jul 2009
Posted 2009-07-04 6:46 PM (#107527 - in reply to #107523)
To clarify:
This rocking is happening even when I am at a "stop"  The horses are not moving around in the trailer either...  It almost feels like the shocks arent working???
Posted 2009-07-04 8:02 PM (#107528 - in reply to #107523)
I don't think that trailer has shocks.... Something has to be shaking the trailer, you, the horses, the wind, an earthquake, etc...  It ain't going to shake from side to side, sitting still, all by itself, unless it's possessed or something.....
giddyupmatt
Reg. Jul 2007
Posted 2009-07-04 9:14 PM (#107529 - in reply to #107523)
A very large half-full water tank ?????   Maybe
hogtownboss
Posted 2009-07-05 12:08 AM (#107533 - in reply to #107523)
10001001001002525
Need WAY more details!  Does it move with NO horses loaded?  If not there is the answer, it is the horses or one of the horses moving, taking a step, moving his/her head, rubbing their butt or any little thing at all will rock that small of trailer!
The trailer has NO SHOCKS, it should have rubber torsion axles which will have NO movement at a stop.
Posted 2009-07-05 1:25 AM (#107536 - in reply to #107523)
If this occurs empty... Loose lug nuts??? Bad Axle connections??? Broken frame??? With horses in it...you may have a BAD BALANCE POINT...and the horses are making your hitch connection LIGHT...
Edited by PaulChristenson 2009-07-05 1:28 AM
paint16h
Reg. Jul 2009
Posted 2009-07-05 10:10 AM (#107543 - in reply to #107523)
Thanks.  I will take it out empty today.To see what it does.  It is a two horse slant and I had two horses in it when it happened.  Can you please explain the hitch balance point issue?
Renee
flyinghfarm
Posted 2009-07-05 12:35 PM (#107546 - in reply to #107523)
1000100100
When the weight is practically perfectly balanced over the axles, the trailer will tend to porpoise, sort of easily rock from front to back........this is not what is desired.
Posted 2009-07-05 4:15 PM (#107555 - in reply to #107543)
Originally written by paint16h on 2009-07-05 11:10 AM
Renee
With most 2H BP trailers you will not have an issue with too little a tongue weight. Most 4 Star slant load two horse trailers, have their axles located at the rear of the trailer. The front horse is well ahead of both axles, the second horse is located over the front axle. With any kind of a dressing room, there is usually more than enough weight on the hitch to tow correctly.
IcePonyGoddess
Reg. Nov 2006
Posted 2009-07-05 7:51 PM (#107572 - in reply to #107523)
500100100252525
Horse pawing?? My pony does it all the time, little stinker.
Edited by IcePonyGoddess 2009-07-05 7:54 PM
