How to clean FRP exterior?
Last activity 2009-07-02 3:30 AM
3 replies, 4846 views
kypeep
Reg. Jul 2008
Posted 2009-07-01 11:37 AM (#107422)
Subject: How to clean FRP exterior?
I have a horse trailer made from FRP. Over time, the surface has dulled. Is there any way to get the trailer exterior really sparkling again? Or even half-way sparkling?  I tried various things, but nothing I've tried has done the trick.
MSM
Reg. Jun 2009
Posted 2009-07-01 2:32 PM (#107432 - in reply to #107422)
Subject: RE: How to clean FRP exterior?
I'm sure you tried rubbing compound?  What I've used in the past to bring back surfaces badly faded is Mother's Mag Polish.  It's a mild (grit) but really pulls off a shine.  Give it a chance, you have nothing to lose and everything to gain.
Posted 2009-07-01 4:21 PM (#107440 - in reply to #107422)
If it's a FRP construction, the outside finish is a gel coating of resin. Anything but a very fine polishing compound will DULL the finish. The UV light damages the surface of the resin, oxidizing the finish and causing a dulling affect.
There are many types of marine polishes and "rejuvenators" that are specifically made to address this issue. There are combination products that will remove the dead resin and polish your gel coating. Using a wax with a UV inhibitor will lessen the UV damage in the future.
Here's where I buy my products:
http://www.jamestowndistributors.com/userportal/search_subCategory.do?categoryName=Polishing&categoryId=560&refine=1&page=GRID
Edited by gard 2009-07-01 4:27 PM
kypeep
Reg. Jul 2008
Posted 2009-07-02 3:30 AM (#107459 - in reply to #107422)
Gard - thanks so much!!!!
