Airride Question?
Last activity 2009-06-29 8:43 AM
2 replies, 3288 views
pooperscooper
Reg. Mar 2005
Posted 2009-06-27 3:53 PM (#107158)
Subject: Airride Question?
We recently bought a used trailer that has airride. There are no user manuals with the trailer and this is the first trailer we've ever owned with this on it. Is there any maintenance that we need to do? Is there a way to turn it off when we are not hauling? Should we get a spare air bag in case one goes bad when we are hauling? Any other things we should know about? thanks.
Posted 2009-06-27 4:20 PM (#107159 - in reply to #107158)
Subject: RE: Airride Question?
The kelderman site has some pretty good pictures of the under side of an "air ride" axle set up along with installation instructions... There should be a switch to disconnect power from the battery to the pressure regulator/compressor.... An on/off switch if you will...
http://www.keldermanairride.com/productdetails.php?id=TORSION
http://www.keldermanairride.com/pdf/torsion%206-7-09.pdf
Tresvolte
Reg. Feb 2008
Posted 2009-06-29 8:43 AM (#107222 - in reply to #107158)
Depending on brand it could also be this... http://www.ridesti.com/
There are some other brands out there as well. I would probably contact the trailer manufacturer.
