short bed truck question
Last activity 2009-06-21 7:53 AM
14 replies, 6543 views
qhnpaintluvr
Posted 2009-06-15 2:09 PM (#106485)
Subject: short bed truck question
I'm looking to upgrade from a bumper pull to a gooseneck with a small living quarters. The trailer I'm interested in is an older Featherlite. I have a short bed 3/4 ton hd and wanted to know if I had to be concerned with the trailer not having a tapered nose? Is there a special hitch that I can have installed so it wont interfere?
Thanks in advance for any insight.
hogtownboss
Posted 2009-06-15 2:19 PM (#106488 - in reply to #106485)
Subject: RE: short bed truck question
10001001001002525
B&W hitch has something called a 4" ball extender that shows to work with short bed trucks.  I think they have a website as well.  Try to google it.
genebob
Reg. Nov 2007
Posted 2009-06-15 2:22 PM (#106489 - in reply to #106485)
How wide is the trailer? If it is only 7 feet, you should have nothing to worry about. If you can, hook it up and try it out.
qhnpaintluvr
Posted 2009-06-15 3:11 PM (#106492 - in reply to #106485)
I sent a question to b&w, thanks for the tip.
Unfortunately I don't have a gooseneck hitch installed so I can't try it out :>(
Posted 2009-06-15 3:34 PM (#106494 - in reply to #106485)
http://mrtruck.net/popup.htm
barrelhorses
Reg. Feb 2009
Posted 2009-06-15 9:04 PM (#106506 - in reply to #106494)
 http://www.popuphitch.com/sb1coupl.htm
They make a 9" and a 16" extension.  I have a 9" that I used with my short-bed F350 (2005 model).  It is actually still on the LQ eventhough I now have a long bed.
Edited by barrelhorses 2009-06-15 9:09 PM
rdurst
Reg. Feb 2009
Posted 2009-06-15 9:09 PM (#106507 - in reply to #106485)
Popuphitch.com works great
brendaclemens
Reg. Jan 2009
Posted 2009-06-16 6:31 AM (#106514 - in reply to #106485)
Yes! The Pop up Hitch extender is the way to go! I have the same as you, 3/4 ton shortbed, no angle full front gooseneck. Works fabulous!!! AND the cable to open the ball without crawling into the bed is a major +++++++. can u tell that I love it?
Not too expensive either :)
BlazingCreekBar
Reg. Nov 2008
Posted 2009-06-16 6:38 AM (#106516 - in reply to #106485)
We have the B&W turnover. It seems to stand up to its reviews. I also thought I needed to worry about the short bed so I bought the overpriced 4 inch drop back. I used it once. Basic weight distribution Physics came into play. I did notice a difference in the squat of the truck. I took it out and used the ball that came with the hitch ever since. If you want mine you can have it for half price plus the freight.
Posted 2009-06-16 6:58 AM (#106519 - in reply to #106514)
Originally written by brendaclemens on 2009-06-16 7:31 AM
Yes! The Pop up Hitch extender is the way to go! I have the same as you, 3/4 ton shortbed, no angle full front gooseneck. Works fabulous!!! AND the cable to open the ball without crawling into the bed is a major +++++++. can u tell that I love it? Not too expensive either :)
How do you go about hooking/unhooking your safety chains if you don't have to crawl into the truck bed....?
qhnpaintluvr
Posted 2009-06-16 7:10 AM (#106520 - in reply to #106485)
Thanks everyone for the replies. I thought it wouldn't be a problem but have heard horror stories in the past and didn't want to buy an "accident waiting to happen".
Hank
Reg. Sep 2007
Posted 2009-06-16 12:50 PM (#106535 - in reply to #106519)
Originally written by retento on 2009-06-16 6:58 AM
Our friend has the same setup and doesn't "bother" with the chains and the breakaway.
barrelhorses
Reg. Feb 2009
Posted 2009-06-18 10:07 PM (#106642 - in reply to #106535)
The cable is a nice feature....but I ALWAYS climb up in the bed and hook/unhook the safety chains.  They are there for a reason. Safety is way more important than convenience.
brendaclemens
Reg. Jan 2009
Posted 2009-06-20 6:25 AM (#106712 - in reply to #106519)
I just lean over from the back end of the bed, grab the chains off of the king pin ledge and snap snap..hook then into the loops on the bed floor. I could reach the ball hook up before like this, but do not have the leverage or strength to pull the pin/push the pin for conventional hook up...pop-up makes it easy. Now, If I have my tailgate on...I have to crawl a bit...but since I have dented up two gates in as many years...it is usually off!
MichaelD
Reg. Apr 2004
Posted 2009-06-21 7:53 AM (#106733 - in reply to #106485)
Has anyone used the 16" Popup? I have the 9" and my trailer will still hit the truck if I turn too sharp. The truck is an 04 dodge 3500 SRW quadcab. The trailer is an 8' wide Adam it is tapered some maybe down to 7'-7'6".
Thanks
Mike
