Tires
Last activity 2009-06-03 8:20 PM
8 replies, 5898 views
Gone
Posted 2009-06-03 7:59 AM (#105872)
Subject: Tires
10002525
Hi,
Carlisle Radial Trail ST 235/85 R16 on 8000# axles.
I want to change them out. I would honestly appreciate suggestions on the best tires available. It seems there are pro's and con's with alot of them which makes it a little frustrating.
Edited by Gone 2009-06-03 8:55 AM
brew26
Reg. May 2009
Posted 2009-06-03 8:46 AM (#105875 - in reply to #105872)
Subject: RE: Tires
Well you gotta ask yourself how much you want to spend on tries because they are not cheap. I'm pretty sure I have goodyear wranglers on never had problem or a flat with them.
Posted 2009-06-03 9:16 AM (#105876 - in reply to #105872)
Subject: RE: Tires
I'm not going to tell you any more, bite the bullet and get a set of.... Goodyear Unisteel G614RST. They only come in one size.
LT235/85R16 load range "G"
http://www.goodyear.com/rv/products/g614rst.html
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
Posted 2009-06-03 9:29 AM (#105877 - in reply to #105872)
Subject: RE: Tires
You've been a member of this forum for several years and read the many discussions about tires. By now you should know the general consensus about Carlisle tires. Your question has been often asked, and a search will reveal a great deal of information.
Gone
Posted 2009-06-03 10:15 AM (#105887 - in reply to #105872)
Subject: RE: Tires
10002525
A final thanks. I found a local company and priced them out at $1100 installed. These people deal with semi's and regular vehicles. It is going to be a couple of months before I can switch. They are a little higher than what I expected. Thanks again....
Posted 2009-06-03 10:23 AM (#105891 - in reply to #105872)
Subject: RE: Tires
That's about right, around here they're $275.00 a piece/each/one single tire put on, balanced and blown up... And that was with a one legged, cigar chewing, retired fireman, farmer discount!! Don't know what they would have cost, had I made him mad!
wyndancer
Reg. Apr 2007
Posted 2009-06-03 10:29 AM (#105893 - in reply to #105872)
Subject: RE: Tires
We just switched a friend trailer, that has 8k axles, over to 215/75R-17.5's...Kumho.
5 wheels, 5 tires, 32 studs (5/8") and 32 flanged nuts, mounted...me doing the work....$1980
She was looking at $325/ea on the Goodyear 614's.....she's set for a long time now.
Posted 2009-06-03 6:45 PM (#105929 - in reply to #105893)
Subject: RE: Tires
Originally written by wyndancer on 2009-06-03 11:29 AM
We just switched a friend trailer, that has 8k axles, over to 215/75R-17.5's...Kumho.5 wheels, 5 tires, 32 studs (5/8") and 32 flanged nuts, mounted...me doing the work....$1980She was looking at $325/ea on the Goodyear 614's.....she's set for a long time now.
Well, at least until she runs over some tire-flattening road debris...
wyndancer
Reg. Apr 2007
Posted 2009-06-03 8:20 PM (#105930 - in reply to #105929)
Subject: RE: Tires
Originally written by PaulChristenson on 2009-06-03 6:45 PM
But on the bright side, the tire is just a tad over $200, instead of a tad over $300 for the 614's
60
