Sealing my leaking old Sundower Trailer
Last activity 2009-05-21 7:16 AM
8 replies, 5839 views
slchast
Reg. May 2009
Posted 2009-05-19 10:39 AM (#105158)
Subject: Sealing my leaking old Sundower Trailer
I have a 1985 Sundowner horse trailer with a small LQ. This trailer leaks when it rains. My hubby had tried to "patch" where we think it is leaking but that is just not working. He has decided we need to clean out all the seams and put new calk in. I would like to know what you all recommend to use to re calk with. Or any other ideas would be great. My plan is to trade this trailer in when I get my truck paid off (2.5 years) so I do not want to spend too much but I am tired of wet bedding
Thanks
Shannon
Missouri
Penejoe
Reg. Oct 2006
Posted 2009-05-19 11:03 AM (#105161 - in reply to #105158)
Subject: RE: Sealing my leaking old Sundower Trailer
I had a 93 sundowner that I completed removed all the old caulk and recaulked with some stuff I got at an Exiss dealer. I am at work and forgot what the name of it is (sorry) but you might want to call a trailer dealer or an rv dealer and they will fix you up. Let me warn you it was a JOB.
Diana
Reg. Jan 2009
Posted 2009-05-19 12:30 PM (#105169 - in reply to #105158)
I just sealed the roof of my Exiss with a Self-leveling lap sealant that we bought from a local RV store. I did not remove the old stuff. I scrubed it clean with warm water and a little bleach to remove any grim and dirt build up, let it dry and then caulked it. Some spots needed a heavier coat then others. It took 4-10.3 fl oz tubes to do my 4 horse trail it is approx 30' long. The cost per tube was about $8.00. So $50.00 plus a good 1/2 day work and your good to go.
Pmoore
Reg. Jul 2008
Posted 2009-05-19 10:17 PM (#105197 - in reply to #105158)
There is a sealing tape you can buy at the big box stores that is not too expensive and it works, It is about 8 inches wide and we just put it over the old seam and caulk, No leaks!
Pat Moore
slchast
Reg. May 2009
Posted 2009-05-20 6:43 AM (#105203 - in reply to #105158)
What is a big box store?
Shannon
Posted 2009-05-20 6:51 AM (#105204 - in reply to #105203)
Originally written by slchast on 2009-05-20 7:43 AM
Shannon
Lowes Home Improvement, Home Depot, Menards, etc...
terri s
Posted 2009-05-20 7:55 AM (#105208 - in reply to #105158)
500100100100
Mine has the tape too-about 5 years now and no problems leaking or the tape coming loose.
Rose66
Reg. Dec 2006
Posted 2009-05-20 9:46 PM (#105268 - in reply to #105197)
Originally written by Pmoore on 2009-05-19 10:17 PM
Pat Moore
Can you give me a brand name on this sealing tape, please?
Tim
Reg. Dec 2003
Posted 2009-05-21 7:16 AM (#105273 - in reply to #105158)
I know at Lowes, it's called Peel and Seal.  Clean the area first with a scratch pad or the like, then alcohol, then apply the tape.  Be careful, when you put it down, it's stuck for good
ood
Edited by Tim 2009-05-21 7:19 AM
