Update on Cummins/ Onan Generator P4300ie
Last activity 2009-05-19 11:39 AM
5 replies, 6815 views
hogtownboss
Posted 2009-05-17 3:21 PM (#105044)
Subject: Update on Cummins/ Onan Generator P4300ie
10001001001002525
We finally got to use our new generator over the weekend.  Ran it for right at 8 hours on 1 tank of gas.  Did not use the power saver mode, so I could get a real time out of it.  Had the a/c set at 65 on med. all night long.
Did turn on the power save mode the next morning to see what I could use and not bog down the generator.  a/c on same setting as above, microwave, all lights, then with a hair dryer it bogged down just a little.
The trailer next to use had a Honda EU3000 and with a hand full of people around to give their opinion, the noise level was the same, but the Honda had to be filled up after 6 hours!
So, bottom line, this is a great generator!
mules4
Reg. Jul 2007
Posted 2009-05-18 7:27 PM (#105104 - in reply to #105044)
Subject: RE: Update on Cummins/ Onan Generator P4300ie
Thanks for the info. I have a Platinum/Outlaw trailer and I am very dissappointed in the Onan Micro-quiet. It is NOT micro-quiet.
genebob
Reg. Nov 2007
Posted 2009-05-18 10:35 PM (#105121 - in reply to #105044)
Saw the Cummins/Onan 4300 at the MN Horse Expo. The dealer I bought my trailer from had them for about $1500. When I saw that I wished I would have known he had them before I bought my Honda 3000eu.
Oh well> Got mine with about 40 hours on it for the price of a 2000eu. Lived this many years camping without a genset so I am sure we will survive with the 3000.
Posted 2009-05-18 11:41 PM (#105123 - in reply to #105044)
Originally written by hogtownboss on 2009-05-17 4:21 PM
It is interesting that they give the following data in their own literature...- 5.3 Hour Continuous Operating Time (At rated load) http://common.csnstores.com/common/marketing/Onan/OnanInverterGener...
Edited by PaulChristenson 2009-05-18 11:43 PM
horsey1
Reg. Dec 2004
Posted 2009-05-19 8:08 AM (#105135 - in reply to #105104)
Originally written by mules4 on 2009-05-18 7:27 PM
Well- Obviously a smaller unit removed from the trailer will be quieter. But yours is much easier to pack & haul- Because it always is packed!
hogtownboss
Posted 2009-05-19 11:39 AM (#105166 - in reply to #105123)
10001001001002525
It is interesting that they give the following data in their own literature...- 5.3 Hour Continuous Operating Time (At rated load) http://common.csnstores.com/common/marketing/Onan/OnanInverterGenerators.pdf[/QUOTE]
At rated load!  Just running the a/c and refrig. is nowhere near the rated load for this generator.  Therefor if you are not running at the "rated load" you will not be using as much fuel and when you use less fuel you will be able to run longer hours!
Would be the same as say a truck one person has a truck and stated they get 12mpg and the next perosn has the smae type truck and state they get 15mpg.  All come down to driving habbits.  For instance my truck will get 14.783mpg (avg 14.5 on 3 tanks) unloaded @ 75mph, but thursady I did a test and filled up then every chance I could I would set the cruise on 65mph and rechecked the mileage tonight and I am getting 16.946mpg, so by slowing down I gained over 2mpg and extended my fill up time.  So this goes the same for the generator run time, if I was to turn everything in the trailer on and run the generator @ full load I' sure it would only run 5.3 hours......
Edited by hogtownboss 2009-05-23 11:17 PM
