Western Saddle Rigging
Last activity 2009-05-26 6:44 PM
6 replies, 8658 views
barstow
Reg. Feb 2007
Posted 2009-05-17 9:16 AM (#105036)
Subject: Western Saddle Rigging
According to one saddlemaker, and a few opinions on some forums, in-skirt rigging on western saddles should be avoided.
"There should be NO in skirt rigging. Rigging in the skirt causes the skirting to bear weight. When skirting bears weight, it cannot protect the horse. The skirt will pinch the horse when the rigging is tightened. The horse's body motion will cause the saddle to move backwards on the horse's back. A breast collar will stop that movement, but will probably tip the saddle up on its front end and cause the gullet to pinch the horse's shoulders and force the horse onto its forehand.In skirt rigging came about as a design adjustment which was required when some saddle makers decided to get rid of the rear cinch."
Any opinions here on inskirt rigging vs ring rigging or flat plate rigging (where the rigging is attached directly to the tree)?
It appears to me the more affordable saddles are all in-skirt rigging, but since my problem is that the saddles I've tried, pinch my horse's shoulders. I may have to choose a saddle with a different kind of rigging. (read: much more pricey) -
A review of some better-quality saddle makers (ie Crest Saddlery, Courts, Coats, Dixieland) shows that most of their saddles are made with ring or flat plate rigging. Most but not all. I know that inskirt rigging provides closer contact with the horse and is less bulky.
Does anyone have a saddle with an in-skirt rigging that you feel fits your horse well and does not cause the problems as described above? Or, do you know of a more affordable saddle (under $1K) that offers ring or flat plate rigging?
Marla
Reg. Mar 2008
Posted 2009-05-17 11:25 AM (#105039 - in reply to #105036)
Subject: RE: Western Saddle Rigging
500
There are a lot of places to buy used saddles and tack. Your local feed store is a good resource. I don't like in-skirt rigging. You can get a pretty good properly rigged saddle around here for around 500 bucks. Marla
huntseat
Posted 2009-05-17 8:47 PM (#105048 - in reply to #105036)
1000500100100100100252525
Lots of folks selling saddles, I'd think you could get a really well made saddle for a steal if you just look around.
jakey1
Reg. Dec 2003
Posted 2009-05-21 8:41 AM (#105277 - in reply to #105036)
I agree... if you can't afford a new well made saddle, then look for a used well made saddle.  There are lots of folks out there selling good stuff because they can't afford to stay in the "horse" hobby these days.  Don't buy a poorly made, lesser quality saddle just because the price tag works better for you.  You will not be happy in the end.
rose
Posted 2009-05-21 10:43 AM (#105284 - in reply to #105036)
10005001002525
Center fire rigging seems to work very well for us. See saddles at www.nationalbridle.com
I have several saddles with in skirt rigging and have not had the problems described. I prefer an english saddle to western but use a western style endurance saddle with cernter fire rigging fron National Bridle on a regular basis. Just my 2 cents.
barstow
Reg. Feb 2007
Posted 2009-05-25 6:12 AM (#105416 - in reply to #105036)
I took the plunge and purchased a Black Rhino with a #2 tree. It has the ring rigging. Buying saddles over the internet is challenging. I sent pictures of my horse and the saddle to the saddle maker, Dave Genadek who said it may be work. But even if it doesn't, he said I could easily re-sell it for more than I paid...I will let you know how I make out!
bjhouten
Posted 2009-05-26 6:44 PM (#105495 - in reply to #105036)
5002525
I've used both the ring and the in-skirt rigging. I gone with the in-skirt rigging for my saddles. I have two top of the line cutting saddles from different saddle makers. My gaited horse saddle has the three point rigging. I don't think the ring get's you anything but a leg rubbed raw. If your saddle fits, slipping not a problem. I would not avoid a good saddle that has the in-skirt rigging if the saddle otherwise meets your needs. -Betty
