What do you use under your jack?
Last activity 2009-04-27 10:09 AM
15 replies, 7208 views
Flooper
Posted 2009-04-23 10:53 AM (#103811)
Subject: What do you use under your jack?
I've always used a block of 4 x 4 treated lumber under my jack...but we've had a lot of rain lately, and when I went to get my trailer yesterday, the block had sunk down about 6 inches into the soft ground. So I'm thinking of using something different, and wanted to see what other are using. Thanks for any suggestions.
chadsalt
Posted 2009-04-23 11:33 AM (#103815 - in reply to #103811)
Subject: RE: What do you use under your jack?
1000100100100100
Piece of 2x8 about a foot long or a cinder block.......
How heavy is your trailer?  Either way I dont think a 4x4 is much of a "foot" in the dirt?
Posted 2009-04-23 12:38 PM (#103820 - in reply to #103811)
18 inches of 4 x 6 treated lumber scrap.
Or about 100 square inches of ground pressure distribution. (18x6)
Stored in back corner of the truck bed.
Also doubles as a wheel chock if needed.
Price ... cheap, one less piece of trash after deck construction.
hogtownboss
Posted 2009-04-23 12:48 PM (#103822 - in reply to #103820)
10001001001002525
Originally written by hosspuller on 2009-04-23 12:38 PM
I use them same thing, also doubles as a trailer jack to change tires.....
Tresvolte
Reg. Feb 2008
Posted 2009-04-23 12:58 PM (#103824 - in reply to #103811)
Ditto.
genebob
Reg. Nov 2007
Posted 2009-04-23 2:00 PM (#103828 - in reply to #103811)
24"x 2"x12" cca under an 18" x 6"x6". I carry several of the 2x12's in varying lengths for use in leveling the trailer at the camp site. Keep them in a box in the truck box.
greyhorse
Reg. Nov 2005
Posted 2009-04-23 2:28 PM (#103831 - in reply to #103811)
8.5' cross tie (about 10" wide) under dual jacks, I had used 8"X12" blocks but they sink when it rains.
lightonthebay
Reg. Aug 2008
Posted 2009-04-23 2:29 PM (#103832 - in reply to #103811)
My girlfriend's hand.
oldguide
Reg. Sep 2006
Posted 2009-04-23 2:41 PM (#103834 - in reply to #103811)
If you use a wooden or concrete block under your jack or jacks, you might want to consider grounding your trailer.  The jacks are the only metal touching the ground.
Posted 2009-04-23 2:44 PM (#103835 - in reply to #103832)
Originally written by lightonthebay on 2009-04-23 11:29 AM
Either you've a fast jack, or she's very slow   LOL
Seriously... Beware of using cinder blocks.  Unless the pressure is evenly distributed (like in a foundation) the block can crumble and collapse.
Posted 2009-04-23 2:50 PM (#103836 - in reply to #103811)
A couple pressure treated 2"x10"... about 18" long.
Flooper
Posted 2009-04-23 5:06 PM (#103848 - in reply to #103811)
Thanks for all the advice...very helpful. Yeah...I kinda found that the 4 x 4 wasn't quite enough to spread the weight around!!
millironk
Reg. Feb 2009
Posted 2009-04-24 8:46 PM (#103924 - in reply to #103811)
is there anything to the comment about grounding your trailer?
Posted 2009-04-25 4:10 PM (#103939 - in reply to #103924)
Originally written by millironk on 2009-04-24 9:46 PM
Well, if you were just connected to your truck with your landing gear up...You would not be grounded as well...so it seems to be a NBD...
Edited by PaulChristenson 2009-04-25 4:11 PM
Posted 2009-04-26 7:09 PM (#103985 - in reply to #103924)
Originally written by millironk on 2009-04-24 5:46 PM
To add to Paul's comment... A painted landing pad makes a poor ground plate on dry dirt, gravel, even grass.  I would rather depend on the camp site's electrical ground.  It is easily checked with a $5 outlet tester.  If you're using a generator, a ground fault interupter (GFCI) is a good safety feature instead of a driven ground rod.
farmbabe
Posted 2009-04-27 10:09 AM (#104014 - in reply to #103811)
1000500100100
I am not one to worry too much about stuff so I just have two or three boards in the truck- one is longer and wide,then some thicker blocks. My trailer is never unhooked for more than a few days ( except at home of course)
