Removing decals from aluminum?
Last activity 2009-04-21 9:47 AM
4 replies, 7915 views
JustMary
Reg. May 2008
Posted 2009-04-20 4:01 PM (#103687)
Subject: Removing decals from aluminum?
I have some lettering I'd like to remove from an aluminum trailer.  The trailer is older and has been acid washed a few times and the lettering was put on when the trailer was new.  I have removed lettering before, and there was always a silhouette left, even after a good acid bath.  Is there something else I can do?
Thanks!
HWBar
Reg. Nov 2005
Posted 2009-04-20 4:37 PM (#103690 - in reply to #103687)
Subject: RE: Removing decals from aluminum?
1000100100252525
Not unless you want to sand the area down, the lettering has been protecting the aluminum from UV rays/salt/acid rain/acid washes ect. for as long as it has been on the trailer. Sorry, probley not the answer you were looking for.
Barfly
Reg. Jun 2008
Posted 2009-04-21 1:09 AM (#103707 - in reply to #103687)
If your trailer has polished ally then you could try to polish the area with an automotive burnishing compound...I doubt it would completely clear it, but it should clean up pretty good.
Try a small piece first to check.....GOOD LUCK
Tresvolte
Reg. Feb 2008
Posted 2009-04-21 7:45 AM (#103716 - in reply to #103687)
A lot more acid baths after the lettering is off.
Posted 2009-04-21 9:47 AM (#103718 - in reply to #103687)
The aluminum surface under the decal has not been exposed to the elements and has not "aged". To have it look like the rest of the trailer, you will have to artificially degrade its appearance to match the surrounding area.
A green Scotch bright pad on a sander will dull the metal. Several applications of Muriatic acid, will lighten the metal's colouration. If you polish the area, it will be brighter than the rest, just the opposite of what you want.
It's labour intensive, but you can machine polish the original surrounding area to match the area under the decal. If you polished the whole trailer, this would result in a trailer with a brand new appearance.
