Insulation is done... another question.
Last activity 2009-04-14 12:27 AM
9 replies, 5513 views
AQHA 123
Reg. Oct 2008
Posted 2009-04-11 2:09 PM (#103201)
Subject: Insulation is done... another question.
I finished up the insulation of the flooring, bulkhead and bunk area. Thank you everyone who gave suggestions. Gard, I pretty much followed your instructions to the line. It turned out perfect and I rather enjoyed doing it.
I just took the trailer in and had foam spray insulations done to all the walls and ceiling, so the trailer is completely insulated now and ready for the fir stripping.
Here's my next question, I hope I can explain it so it makes sense. The fir stripping will run horizontally on the the vertical aluminum trailer studs. These studs are approximately 1 x 3, maybe 1 x 4, to get maximum temperature control within the LQ should I insulate over those exposed aluminum studs after I run the fir stripping? They are in direct contact with the outer aluminum skin, there will be heat or cold getting in via those studs... It will be behind the tongue and groove but that still seems to me to be a weak spot in the heat control of the trailer. Keep in mind this trailer is being used in Montana and Alaska.
I was thinking I could cut some 1/2 inch foam board into 4 inch strips and caulk it to the aluminum studs after I do the fir stripping to cover them... What do you think, is it over kill or would this help?BTW, where do I get SS self tapping inch and a half bugle head screws for the attachment of the fir stripping to the studs? I checked the big box stores and they don't carry them. Is it a special order?
Edited by AQHA 123 2009-04-11 2:10 PM
flyinghfarm
Posted 2009-04-11 2:13 PM (#103202 - in reply to #103201)
Subject: RE: Insulation is done... another question.
1000100100
http://www.awisupply.com/
Try ordering them from these folks....
AQHA 123
Reg. Oct 2008
Posted 2009-04-13 12:50 PM (#103285 - in reply to #103201)
I will check it out. Any other help guys???
wyndancer
Reg. Apr 2007
Posted 2009-04-13 1:29 PM (#103287 - in reply to #103201)
http://www.mcmaster.com/#94195a130/=1fhepf
This will be a start, search for your application
Edited by wyndancer 2009-04-13 1:31 PM
Posted 2009-04-13 4:31 PM (#103295 - in reply to #103201)
Originally written by AQHA 123 on 2009-04-11 2:09 PM
It's too bad you didn't have the end of the studs foamed too. The aluminum is a direct conductor of heat and cold. Its inner surface will provide a point that will allow any interior heat escaping into the void before your insulation, a place to condense and pool water vapor.
This weekend we continued the installation of the Exiss LQ, and we covered the stud ends with insulation, hoping to avoid this problem.
We have used a little over two boxes of SS pan head 6 x 1" screws so far on a 4' SW LQ. You can get them here:
http://www.jamestowndistributors.com/userportal/main.do
Edited by gard 2009-04-13 4:34 PM
AQHA 123
Reg. Oct 2008
Posted 2009-04-13 5:38 PM (#103302 - in reply to #103201)
Here's what I did with the spray insulation. The ends are covered...
AQHA 123
Reg. Oct 2008
Posted 2009-04-13 5:48 PM (#103304 - in reply to #103201)
Heres the pics... I hope.
AQHA 123
Reg. Oct 2008
Posted 2009-04-13 6:31 PM (#103306 - in reply to #103201)
Okay, I guess not. Posting pics is above my pay grade I guess. Sorry. Anyway, the foam spray was spayed in all even with the studs most inner surface.
Posted 2009-04-13 9:21 PM (#103320 - in reply to #103201)
If the studs are completely covered, you can install your interior. You shouldn't have any condensation problems.
AQHA 123
Reg. Oct 2008
Posted 2009-04-14 12:27 AM (#103327 - in reply to #103320)
Originally written by gard on 2009-04-13 9:21 PM
Well, crap. I thought I only needed to put the insulation on the inside of the outer skin about an inch or so thick. I had it put in there good but its not covered the studs. I thought the most inside of the stud needed to be left clear of the insulation so I could put the fir strips on. The sides of the studs are covered of course, but not the surface that faces the inside of the LQ. Now Im very confused.
