Light issues
Last activity 2009-04-11 10:41 AM
6 replies, 4414 views
stef73433
Reg. Jun 2005
Posted 2009-04-10 8:43 PM (#103156)
Subject: Light issues
Ok, we tested all the lights/plug on my truck, that is all fine. My adapter plug seems to work good. So I have narrowed down my issue to the trailer. I have brake lights, turn signals, but no clearance lights. They are on ever so dim that you can hardly tell. When you plug trl into truck, it makes my taillights dim on truck. I am supposing there is a short somewhere. Where do I even start to figure it out?Could a bad trailer light plud do this?
All lights worked when we hooked it to our other truck last week, but we had no brakes...
greyhorse
Reg. Nov 2005
Posted 2009-04-10 10:41 PM (#103163 - in reply to #103156)
Subject: RE: Light issues
Sounds like it might be on the truck side still if the truck lights dim, a short should blow a fuse. Maybe a bad connection somewhere on the truck that doesn't let enough electricity go through.
windy
Reg. Oct 2004
Posted 2009-04-10 11:05 PM (#103166 - in reply to #103156)
I'll start off by saying trouble shooting an electrical problem is not my favorite thing- probably because I know just enough to be dangerous, but not enough to know really what I'm doing. That being said, take my advice with a grain of salt! I'd probably start by looking for a bad ground on the trailer, the plug, the lights themselves.  Good luck!
Posted 2009-04-10 11:57 PM (#103169 - in reply to #103156)
Originally written by stef73433 on 2009-04-10 9:43 PM
Why do you need an adapter?
brushycreekranch
Reg. Jun 2006
Posted 2009-04-11 7:58 AM (#103185 - in reply to #103156)
500100100100100
A few years back, we had the same issues with our trailer lights when using an adapter. To fix it, we had to change the smaller  older plug on the trailer to the more modern large round that matched what all the newer trucks were coming out with from the factory. Those adapters are only meant to be a temporary fix. We found that the ones from the big box stores like Walmart were the worst. If you are unwilling or unable to loose the adapter, then order one of the best made ones available from the trailer dealer.
Most LQ trailers should never have the smaller light plug.  And, a horse trailer should never have a flat boat plug.
Posted 2009-04-11 9:23 AM (#103190 - in reply to #103156)
Ditto the previous threads about the adapter. Change your trailer plug to match your truck.
stef73433
Reg. Jun 2005
Posted 2009-04-11 10:41 AM (#103193 - in reply to #103156)
I have a small round on the trailer and big round on my truck which is why i use adapter. i will change the small round to match my truck, then I will let you know what I find.
