Water tank in hay rack
Last activity 2009-04-10 9:34 PM
20 replies, 8335 views
Slidinspots
Posted 2009-04-08 11:53 PM (#102988)
Subject: Water tank in hay rack
I just put a water tank up in the hay rack. I did buy the green tank so algae won't grow. First question is that it came with 2 narrow nylon straps with double D slip rings for fastening. It also had a screw/washer to screw the strap to the trailer. I took the screws off and wrapped the strap around a rib of the hay rack and then the tank. When I used the slip D, I then tied a knot in the end. Will this hold or should I get something more substantial for tieing the tank up there?
Second question concerning the hose. I have it coming down the ladder and used cable ties towards the top but what is best to secure the bottom of the hose and easily undo it? Currently I have a plastic, ratcheting thingy used to store electric cords, etc. to hold it on the ladder so it doesn't flap in the breeze. Better ideas?
Posted 2009-04-09 1:40 AM (#102991 - in reply to #102988)
Subject: RE: Water tank in hay rack
How many gallon tank are we talking about?
Angelmay84
Reg. Jan 2008
Posted 2009-04-09 5:44 AM (#102995 - in reply to #102988)
Heh...I have the same tank and the same questions.  I woud up using those black rubber bungee tarp straps to hold mine down.  The straps that came with the tank are pitiful.  Really, I don't think that when the tank (35gal) is full of water it will move any more than a bale of hay would.  I tied my hose in a knot and secured it with a piece of bailing twine for now.  I'm going to get some of those velcro things you get in the electronics dept.  to hold loops of wires together and see if that keeps the end under control.  I got my tank for christmas, and I haven't gotten to use it yet....stupid Illinois weather!
Amanda
Posted 2009-04-09 5:45 AM (#102996 - in reply to #102988)
quote: Second question concerning the hose. I have it coming down the ladder and used cable ties towards the top but what is best to secure the bottom of the hose and easily undo it? Currently I have a plastic, ratcheting thingy used to store electric cords, etc. to hold it on the ladder so it doesn't flap in the breeze. Better ideas?
bungie cord maybe??
So far as strapping the tank down.... I would buy a pair of ratchet straps, hook either end to the hay rack and ratchet them snug against the tank.
http://www.walmart.com/catalog/product.gsp?product_id=893755
threeman
Posted 2009-04-09 6:26 AM (#102999 - in reply to #102988)
10010010025
I used tie wraps all the way down the ladder rack, used enough slack up top so that the ladder can move (mine is on the door).  I changed the end of the hose to a female connection so that you can just attach the water hose directly to it to fill.  Also the valve that comes with them is kinda crappy and slows flow.  I put a ball valve about waist high from the ground so that I can just swing the bucket under with the bucket strap, turn on the water, and never bend over.  You learn things when your back is out regularly.
Mine works with enough gravity fed pressure that it flows like its pump fed.  Works good I have two trailers setup like that.  If I have another it will be also.
Posted 2009-04-09 9:38 AM (#103013 - in reply to #102988)
One of the trailers I used to own, came with that same water tank installed in the hayrack.  With the two nylon straps. I added an additional nylon web strap, (that had the adjustabe cam binder) and used this for several years with no problems.
When I stood on my trailers cat walk, I could reach the tank outlet, so I just unscrewed the hose when not in use and re-installed it when I set up camp.
Slidinspots
Posted 2009-04-09 9:40 AM (#103014 - in reply to #102991)
"How many gallon tank are we talking about?"
40 gallons
Slidinspots
Posted 2009-04-09 9:41 AM (#103015 - in reply to #102995)
"I'm going to get some of those velcro things you get in the electronics dept. to hold loops of wires together and see if that keeps the end under control."
That was the first thing I thought of but was afraid the velcro would get dirty and not hold.
Slidinspots
Posted 2009-04-09 9:48 AM (#103017 - in reply to #102995)
"I don't think that when the tank (35gal) is full of water it will move any more than a bale of hay would."
It isn't full coming home. A friend said he lost one and I am waiting to hear from him about how it was or wasn't tied down. I also heard of someone losing a bale of hay out of the hay rack.
IcePonyGoddess
Reg. Nov 2006
Posted 2009-04-09 9:55 AM (#103019 - in reply to #102988)
500100100252525
Those straps tend to slide around and loosen up. I use a Ratchet Tie Down Strap on each tank. Those do not move at all.
genebob
Reg. Nov 2007
Posted 2009-04-09 11:11 AM (#103029 - in reply to #102988)
Angelmay- DO NOT USE THE RUBBER BUNGEES TO TIE DOWN THE TANK! They are rubber, they stretch, get weather checked, break for no reason. Sometimes they even just come unhooked. The last thing you want is to lose that tank into somebody's windshield while going down the road @ 60 mph.
Use the ratcheting tie downs. They will hold the tank secure. Remember, 35 gallons is 280 lbs. on top of your trailer. Water sloshing around changes the weight distribution on CONSTANT basis. That tank will move a lot easier than a bale of hay. It will also effect your driving.
Posted 2009-04-09 1:38 PM (#103044 - in reply to #102988)
Genebob... I mentioned the bungee's for strapping that loose hose end that's flapping on the end of the ladder... I didn't meant for the tank. I gave here a link to some ratchet straps for strapping down the tank.
flyinghfarm
Posted 2009-04-09 1:55 PM (#103047 - in reply to #102988)
1000100100
Ours is on with 2 rachet style straps, the down-hose has a cut-off fitting with a female fitting on past it, I use a small bungie that wraps around it twice at the bottom, have  zip ties on up the ladder to keep it from shaking around.  I fill and drain from the bottom of this hose, works great.
Angelmay84
Reg. Jan 2008
Posted 2009-04-09 4:16 PM (#103056 - in reply to #102988)
The problem is that I can't make the ratchet straps work. My hay rack has a metal mesh floor. I can't figure a way to get the ratchet straps to fasten without the metal ratchet hitting against the tank. I was afraid of causing damage to the tank. Maybe I just bought a crappy set...and I've never ratcheted anything down in my life.
Amanda
Posted 2009-04-09 7:26 PM (#103064 - in reply to #102988)
Just use some CAM straps rather than the ratchet straps.  They have less bulk, and elss chance of rubbing a hole in the tank.  You can't torq them down as tight as a ratchet strap. But you can fasten them tight enough to do the job.  I've attached coolers, all my gear for week long white water river tips into my rafts with these type of straps. And they have held up great.
Here is an example of what I mean by a CAM strap.
http://www.strapworks.com/Metal_Cam_Straps_p/cs34h.htm
If your trailer has a mesh bottom or side. You may have to make something to connect the strap to.  Maybe a carrabiner or a heavy wire that you can weave through the mesh.
Edited by Painted Horse 2009-04-09 7:28 PM
genebob
Reg. Nov 2007
Posted 2009-04-10 12:04 AM (#103095 - in reply to #102988)
Retento- I was talking to AngelMay. She was the one who said she was using bungees and didn't think it would move.
Sorry if I missed the point.
Slidinspots
Posted 2009-04-10 11:29 AM (#103123 - in reply to #102988)
I talked to my friend who lost his tank. He was using the straps it came with, the slip Ds. They slipped so no longer tight and the tank slipped out of the ties. To correct he put angle aluminum on the rack around the tank so it cannot move and added straps for plumbing, with all the holes and you use a srew to tighten [don't know what they are called, not sure my description is good LOL!]. So I am going to go find a ratchet strap or cam strap today.
I am concerned about quality of ratchet straps. I used some for my hay for cross counrty last fall. Taking them off, the ratchets broke on most of the straps. So coming home we had to tie all the straps.
Posted 2009-04-10 11:40 AM (#103124 - in reply to #102988)
Anther consideration when using the ratchets and straps, is the longevity of the straps. Most are Chinese and will quickly break down with constant exposure to sunlight. We've had many fail in a year's time of constant usage.
Posted 2009-04-10 5:28 PM (#103145 - in reply to #102995)
Originally written by Angelmay84 on 2009-04-09 6:44 AM
Amanda
Bungees will NOT hold 280 lbs and if that tank were to come off your trailer it would go right through a windshield...Get better STRAPS...
Slidinspots
Posted 2009-04-10 8:01 PM (#103154 - in reply to #103145)
In Washington there is a hefty fine for anything coming off your vehicle. I talked to another today who lost a tank by just using the straps with the slip dees.
I got some ratchet straps today. They had some cam straps but they were pretty light weight, only rated for 150lbs.
flyinghfarm
Posted 2009-04-10 9:34 PM (#103160 - in reply to #102988)
1000100100
Slidinspots,  I think the strap with the holes in it is called plumbers tape, or something like that.  Your description was eloquent!
