Water Supply
Last activity 2009-04-07 5:33 PM
2 replies, 4600 views
Kesta
Posted 2009-04-04 4:01 PM (#102744)
Subject: Water Supply
Currently, my trailer's water supply is a hose hooked up to a hydrant and then coupled to a connector on the side of the trailer.  There is no tank or pump.  Turn on the kitchen faucet and I have water, however it leaks badly.  Probably due to too much water pressure.  A pressure regulator will probably fix that problem.  There is also no gray tank to hold the waste water, it just drains on the ground (I usually put a bucket underneath).  I bought the trailer with this setup and it works fine for most small show grounds where I'm parked in gravel or in a field, but a lot of places won't allow this.
I would like suggestions as to the most economical way to change this setup.  Hot water would be nice, too.  I just bought, but haven't tried yet, a commercial coffee maker.  I thought I could heat my water in it and place it on the counter with the spigot over the sink for my hot water supply.  I have a porta-potty and solar shower setup in the back, but if I had hot water inside, I could at least do a sponge bath on cloudy/cool days when the solar/bag shower water wouldn't get warm enough.
Thoughts/suggestions?
LoriA63
Reg. Mar 2009
Posted 2009-04-07 12:11 AM (#102878 - in reply to #102744)
Subject: RE: Water Supply
I have heard good things about these:
http://www.americanwaterheater.com/products/pdf/lpe70.pdf
Don't know about the waste water issue. i would contact an RV service center and ask for suggestions..
mingiz
Reg. Jul 2004
Posted 2009-04-07 5:33 PM (#102918 - in reply to #102744)
I had basically the same set up on a trailer with a diy lq they had a electrical box in it and wired it for 30amp service It has a electric water heater and the water supply was same as yours. Never had any problems with leaking. Had no holding tanks either. When I coldn't let the grey water out on the ground I used a portable tank that you could empty at a dump station or at home. I also had a porta potty but had a shower and sink. Had a small elec fridge. When I rough camped I took a generator to run it. I was going to redo it and add tanks but the way they set the bathroom up they had the hole cut for a rv toilet but didn't leave enough room and it was directly over the axels. So I ended up selling it and picked up a full lq...When I did camp I used a water tank with a flo jet pump mounted on it and had a plug that was wired into the trailer battery box, when i needed water it was like at home and no pressure on the spigot.
