F250 Hitch weights
Last activity 2009-03-19 1:57 PM
3 replies, 3592 views
Wilbur01
Reg. Jan 2009
Posted 2009-03-18 7:29 PM (#101718)
Subject: F250 Hitch weights
I am using a 3 horse, 8' short wall 8' wide trailer for the summer. I just pulled the trailer 1000 miles with no problem with my 2004 F250 with air bags. I took it to the scale the other day and have found that the hitch weight is 3700lbs. If I had not taken it to the scale I would have never guess it was that high. The total weight of the trailer is 11500lbs. I am not worried about the total weight as I have pulled an 13500 lbs RV for years with no problem. I am worried what happen when I put 2 horses in the trailer. Will that add more hitch weight or remove some as the horse are behind or at the axles of the trailer? The rear axle of the truck with the trailer weights 6400lbs. I know that I am over, but what are other people pulling? I have seen many SWR trucks pulling much bigger trailers. Any idea?
BlazingCreekBar
Reg. Nov 2008
Posted 2009-03-18 8:37 PM (#101721 - in reply to #101718)
Subject: RE: F250 Hitch weights
Here is a good site to get all your towing capacities.
https://www.cvpi.com/showroom/rv_trailer_towing/2004/2004_default.asp
Edited by BlazingCreekBar 2009-03-18 8:37 PM
Posted 2009-03-18 9:28 PM (#101723 - in reply to #101718)
Originally written by Wilbur01 on 2009-03-18 7:29 PM
 I am worried what happen when I put 2 horses in the trailer. Will that add more hitch weight or remove some as the horse are behind or at the axles of the trailer? ?
I don't know what brand trailer you have. Many three horse trailers are set up so that the center of the two axles is under the shoulder side of the horse. That means with one horse in the center stall, very little additional weight is added to the hitch.
On a gooseneck trailer, because of its relatively heavy hitch weight, you can carry a horse behind the axle without causing any tracking problems. You will only slightly unweight the hitch, which if I read you correctly, would be to your advantage.
Carrying two horses, one in the center stall and one in the rear most stall should not adversely effect your hitch weight, and would not cause any tracking or trailering problems.
We consistently load like this and use the front stall to carry hay, tack boxes and an electric bicycle.
gabz
Posted 2009-03-19 1:57 PM (#101761 - in reply to #101718)
1000100100100252525
Originally written by Wilbur01 on 2009-03-18 8:29 PM
There are several factors here...  do you have an 8' bed; that is, the long frame or a short frame F250? Reg cab, extended cab, crew cab?
Do you have 4WD or 2WD? Is it the 5.4l or the diesel?
3700 tongue weight is more than 30%... that is very scary. What's the gross vehicle weight rating of the trailer? Sounds like way too much cabinetry in the LQ / front end of the trailer.
A simple check would be to hook everything up, then measure how high from the ground the back bumper of the truck is. Load up the horses and measure again. If the bumper goes UP, then you are removing weight from the hitch; if it goes down, then you're adding weight to the hitch.
Edited by gabz 2009-03-19 1:58 PM
