Horse trailer tires
Last activity 2009-03-13 10:24 PM
4 replies, 6117 views
BES
Reg. Mar 2009
Posted 2009-03-13 7:14 PM (#101314)
Subject: Horse trailer tires
Hi,
I am looking for some help in how to find the correct tire size for my 1986 Trail et baronII horse trailer...the tires on the trailer are not the original tires....and I think they may not be the correct size, also the tires are unreadable as to what is on them now... I have not been able to find any specs for Trail ets online...any advice?
Thanks!
chadsalt
Posted 2009-03-13 7:46 PM (#101315 - in reply to #101314)
Subject: RE: Horse trailer tires
1000100100100100
IIRC your trailer is the 2h straight load bumper pull?
I know a lady who has a 2005 model, it has   ST205/75R-15  on it.  Those tires are appropriate for a 3500# axle.
BES
Reg. Mar 2009
Posted 2009-03-13 8:08 PM (#101317 - in reply to #101314)
yes...2H bumper pull...thank you so  much  we called a trailer dealer that mostly deals with trailers other thatn horse thrailers and they said a ST225/75DI5...I have no ida what that means, or what the difference between what you suggest and that tire might be?  and also...what does load range mean?
chadsalt
Posted 2009-03-13 9:42 PM (#101324 - in reply to #101314)
1000100100100100
The ST225 tire they suggested should also be acceptable, it is the size I have on my 2h trailer.  The difference being that ST225 is slightly larger than the ST205, but should still fit under the fenders.
Load range has to do with the pressure and load a tire can carry.
The ST225 tire can be had in several load ranges;
Load range C  50 psi  ~2150 lbs capacity
Load range D  65 psi  ~2540 lbs capacity
Load range E  80 psi  ~2830 lbs capacity
The ST205 tire is generally found in the Load range C 50 psi with ~1820 capacity.  It is intended for the 3500 lbs trailer axles, which are most likely what you have on your trailer.
Be aware that while there is technically nothing wrong with buying a tire with more load range than you need, the wheel itself will have a max psi rating that can not be exceeded.  However buying a tire with excessive load capacity can cause a rough ride and poor braking ability.
The ST225 at a load range C would be a fine choice and give more than sufficient "safety" margin for the weights you would be carrying.  For example my trailer weighs 6000 lbs, my tires (ST 225 "C") have a total limit of 8600 lbs.
It appears you have a 'somewhat' knowledgeable tire dealer available to you.  With a basic understanding of the options you have, I suspect you and the dealer can arrive at an agreeable conclusion.
BES
Reg. Mar 2009
Posted 2009-03-13 10:24 PM (#101331 - in reply to #101324)
thank you so much for all your input...it has been very helpful...I don't know why, but I just felt the tire guy would not know about a horse trailer, so it is nice to have horse people give their knowledge too!  thanks again
