Tongue Weight
Last activity 2009-03-11 9:45 PM
6 replies, 4329 views
ChocoRockyHolic
Reg. Mar 2009
Posted 2009-03-08 1:55 PM (#100887)
Subject: Tongue Weight
Does anyone happen to know the tongue weight of a 2h straight load WW type trailer?16
Thanks for any help.
chadsalt
Posted 2009-03-09 8:36 AM (#100921 - in reply to #100887)
Subject: RE: Tongue Weight
1000100100100100
Empty or loaded?  Either way not very much, you've got a smaller truck?
I would take a SWAG; a 12% tongue weight of ~300# empty and ~550# loaded.
ChocoRockyHolic
Reg. Mar 2009
Posted 2009-03-09 11:15 AM (#100934 - in reply to #100921)
Hi Chad,
Thanks for the reply! I have an '02 Ford Expedition w/a bumpger installed hitch and on it is printed, "max 400lbs. tongue weight max 4000lbs. trailer weight". I am wanting to pull a 2h straight load w/only one horse in it and am wondering if I should take the chance b/c I know I really should use or install a frame mounted hitch.
thanks again .. this is tough stuff to learn! 12
chadsalt
Posted 2009-03-09 11:30 AM (#100935 - in reply to #100887)
1000100100100100
I think a frame mounted hitch would be a better choice.  Primarily because you dont know the exact weights, and will probably be close to the bumper's limits.  It is unlikely youll be able to haul the trailer level hooked to the bumper.  A trailer that is not level can have handling problems, braking problems, and can overload individual axles.
Got your brake controller, right?
ChocoRockyHolic
Reg. Mar 2009
Posted 2009-03-09 6:49 PM (#100984 - in reply to #100935)
Yes, decided to go w/the hitch and having it installed (mounted) onto the frame for a decent fee by u-haul, surprised me!
Uhmmmmm .... brake controller .. ummm you mean my foot on the brake, right? yah, I know 20
Posted 2009-03-09 9:40 PM (#100998 - in reply to #100984)
Originally written by ChocoRockyHolic on 2009-03-09 7:49 PM
Make sure the frame mounted receiver is set up to fit around the spare tire. Many after market mountings block the removal/access of the tire. The OEM hitches are built to fit around the drop area.
ChocoRockyHolic
Reg. Mar 2009
Posted 2009-03-11 9:45 PM (#101159 - in reply to #100998)
Thanks Gard, I certainly will make certain of that!
