12v
Last activity 2009-03-09 5:19 PM
5 replies, 4440 views
rainmakerrepair
Reg. Mar 2009
Posted 2009-03-05 12:15 PM (#100725)
Subject: 12v
What would the 12v wire be used for on a 7 wire hookup?
Terri
Posted 2009-03-05 12:58 PM (#100730 - in reply to #100725)
Subject: RE: 12v
200050010010010025
Its hard to say.  On one of my trailers its the brakes and on the other its the "hot" wire.    On a friends trailer it is reverse lights (camper).
trguy4820
Reg. Jul 2008
Posted 2009-03-05 3:44 PM (#100740 - in reply to #100725)
Subject: RE: 12v
You talking about a 12V wire or a 12 guage wire?
Posted 2009-03-05 4:08 PM (#100744 - in reply to #100725)
Subject: RE: 12v
All the wires except the brakes are 12v wires. The ones you may be thinking of, using the truck as a power source, would include trailer interior lighting and  battery charging. The rest are your running lights, turn and brakes lights, back up lights and braking circuit. The final wire is a ground.
rainmakerrepair
Reg. Mar 2009
Posted 2009-03-09 3:56 PM (#100963 - in reply to #100744)
Subject: RE: 12v
OK I got that the black/red 12v is for the interior/battery. My brake hub has 2 wires coming out in knew that the blue wire is the brake wire how would I wire them up?
Posted 2009-03-09 5:19 PM (#100967 - in reply to #100725)
Subject: RE: 12v
Your two wires coming from the brakes drum may be blue and black. The blue wires will be connected together and run to the trailer brake wire at your plug. The black wires will be connected together and run to the common ground wire at your plug.
Sometimes the black wires are grounded to the frame, which can cause erratic operation of the brakes when the connections get corroded. It's best to hardwire them directly to the wiring of the plug.
