Brakes grabbing
Last activity 2009-02-27 9:41 AM
7 replies, 7624 views
Fairweather
Posted 2009-02-25 11:40 AM (#100140)
Subject: Brakes grabbing
Twin Sister to Queen Boobie
We're having a problem with the brakes grabbing pretty hard on our trailer -- it's done this with 2 differrent brake boxes and 2 different trucks and different settings on each one.
My husband is the one that drives most of the time and he's pressing lightly on the brakes. It did the same with me on the other truck.
We're also noticing that it's happening when you're re-braking-- meaning that you've hit the brakes and you're backing off of them but then press down on the brake peddle.
jdzaharia
Reg. Apr 2006
Posted 2009-02-25 11:54 AM (#100141 - in reply to #100140)
Subject: RE: Brakes grabbing
1001001001002525
What type of brake controller(s) do you have?
Sounds like what happens when the "leveling" knob isn't quite adjusted correctly on my Tekonsha Voyager.
Barfly
Reg. Jun 2008
Posted 2009-02-26 12:22 AM (#100184 - in reply to #100140)
The fact that it does it with two different trucks, tells me that the problem is with the trailer....when last have you checked the actual brake shoes ? I would strip the drums and check the trailer brakes, adjust them properly and then go for a test drive. It is probably worn or incorectly adjusted brakes....
eclipse
Posted 2009-02-26 7:45 AM (#100189 - in reply to #100140)
I agree with Barfly--that the problem is in the trailer. In addition to checking the brakes themselves, I would check the wiring from the plug all the way to the brakes to be certain the insulation has not been nicked or rubbed off anywhere. I would also take the plug apart and make sure all the wires are tight in their little screws and no bare wires are touching something else.
Posted 2009-02-26 8:18 AM (#100191 - in reply to #100140)
I would do a thorough inspection of the brake assemblies. The retractor springs, cam pivot points and star linkage could be rusty and hanging up. The electrical circuit is working, it's applying the brakes. But if as was stated, different controllers have the same affect, it may be a problem of the brakes themselves.
A complete disassembly, inspection and lubrication with high temp grease may solve the problem. As a last resort, a replacement of the brake shoes may offer a solution.
Fairweather
Posted 2009-02-26 12:09 PM (#100220 - in reply to #100140)
I'm not sure what he's done in regards to the brakes on the trailer. I've forwarded the thread to him at work so he can take a look at it. At least he's got a starting place.
Thanks!
terri s
Posted 2009-02-26 3:30 PM (#100232 - in reply to #100140)
500100100100
Mine did that and it was just exactly what eclipse said-a raw wire shorting out on the trailer plug. I'd start with the easy to check, cheap to fix stuff first. It's usually the obvious that gets overlooked.
tool
Reg. Apr 2008
Posted 2009-02-27 9:41 AM (#100288 - in reply to #100140)
One other possibillity is that you have a leaking inner wheel seal and have gotten a small amount of grease on your brake pads.
For some reason it will make them grab and chatter like that when the brakes are applied sometimes.
