Cleaning and maintaining saddles
Last activity 2009-03-08 12:14 PM
16 replies, 7099 views
shelly1367
Reg. Jul 2008
Posted 2009-02-22 4:34 PM (#99904)
Subject: Cleaning and maintaining saddles
I'm getting ready to clean and "oil up" our western saddles so they'll be ready for riding this spring. However, I never know what is the best thing to use. A cleaner/conditioner, Mink oil, Needs Foot Oil etc.
What are the steps you guys take in preparing your gear for the riding months. I just had new ties and leathers replaced so I know the leather is in good condition and I want to keep it that way!
Thanks!
Posted 2009-02-22 5:22 PM (#99906 - in reply to #99904)
Subject: RE: Cleaning and maintaining saddles
I like the Neets foot Oil. But it has a tendancy to darken the leather, Snce most of my saddles are natural in color, I use the Bicks 4.  It's the only moisturizer that I've found that doesn't darken the leather.
Marla
Reg. Mar 2008
Posted 2009-02-22 6:18 PM (#99911 - in reply to #99904)
500
Leather Nu is also a good product that won't darken the leather.
Marla
gabz
Posted 2009-02-22 8:24 PM (#99924 - in reply to #99904)
1000100100100252525
BICK 4 is my favorite too.
I use a small brush and apply Bick 4 to the UNDERSIDE (raw) of the fenders, jockeys, stirrup leathers etc.  I also lay the saddle upside down on the carpeting and sprinkle a good amount of talcum powder down into the saddle - in those spaces where the leather rubs on the saddle tree. Helps "lubricate" it and gets rid of squeaks.
 I only use Neatsfoot oil on plain, new leather that I want to darken. I do not use it when there is stitching. For new reins, I coil them up in the bottom of a coffee can and pour the Neatsfoot oil in there. Let them sit overnight then rub them dry with toweling.
Mink oil - actually I have a paste -  I use on my boots and leather gloves.
I use the bar saddle soap when I need to really clean something. I make a good lather and use the "suds" to clean the item. I lightly rinse and then I apply Bick 4.
AND... 2 or even 3 LIGHT coats of any conditioner are much better than 1 heavy one.
Posted 2009-02-22 9:19 PM (#99927 - in reply to #99904)
1000500100100100252525
I use saddle soup  and use oil very little
ridingarocky
Reg. Aug 2008
Posted 2009-02-25 5:43 AM (#100111 - in reply to #99904)
500100252525
I have more containers of saddle soap than of people shampoo.. My favorite is stubben glycerin saddle soap, and passier sattelseif... It has a conditioner that you slather on and let sit.. wiping it off before you use the saddle next... I used it on an older saddle that needed softening.. works like a charm..
gemm
Reg. Feb 2005
Posted 2009-02-25 11:38 AM (#100139 - in reply to #99904)
100100100100252525
I like Ko-Cho-Line. It goes on red so you know where you've got enough and where you need more. I let it sit overnight then wipe off the excess the next day. I used it on a cheap pony saddle from Mexico. It looked great when done, and has lasted about 10 yrs now! I'm pretty sure I could sell it for what I paid 'cuz it looks so good and the leather is improved. If I'm in a hurry I use a very light coat of Neatsfoot Oil.
huntseat
Posted 2009-02-25 1:58 PM (#100153 - in reply to #99904)
1000500100100100100252525
When it comes to my English gear I use Olive Oil.  A little goes a long way and makes everything buttery soft.  This treatment only needs to be done once or twice in the lifetime of the item, if soaked in a baggy...every year or two if wiped on with a cloth.  It will darken the leather FYI.
Posted 2009-02-25 9:47 PM (#100176 - in reply to #100153)
Originally written by huntseat on 2009-02-25 2:58 PM
                                                           question dose the olive oil go bad????
huntseat
Posted 2009-02-26 9:32 AM (#100197 - in reply to #99904)
no the Olive oil does not spoil...no refrigeration necessary
crowleysridgegirl
Reg. Apr 2005
Posted 2009-03-04 4:12 AM (#100597 - in reply to #99904)
2000500100
I've used a lot of products over the years such as Leather New,Lexol,ect.I like glycerin saddle soap for cleaning,and I think Leather CPR is the best product I've used yet.
Gone
Posted 2009-03-04 11:55 AM (#100627 - in reply to #99904)
10002525
What's good for cleaning brass?
huntseat
Posted 2009-03-04 4:01 PM (#100652 - in reply to #99904)
Gone, the brass cleaner I really like is called Barkeepers friend.  You can find it in many large retailers, walmart, lowe's, etc.
 http://www.barkeepersfriend.com/
Another great choice would be Nevr-dull
http://www.nevrdull.com/
Edited by huntseat 2009-03-04 4:10 PM
Terri
Posted 2009-03-04 4:35 PM (#100658 - in reply to #100627)
200050010010010025
My husband uses brasso or MASS for the brass on his uniforms.
Gone
Posted 2009-03-04 5:43 PM (#100670 - in reply to #99904)
10002525
Barkeepers friend? I'm going to have to give it a try. Thanks....
I use Leather New on my saddles....So far, so good.
AQHA 123
Reg. Oct 2008
Posted 2009-03-07 4:28 PM (#100855 - in reply to #99904)
I'm a saddle maker so I can tell you a few things that might help. Most builders recommend you use Neatsfoot Oil. There are two kinds, 100 percent pure and then Neatsfoot Oil Compound. The Neatfoot Oil Compound tends to darken the leather faster. Some like this but most don't. Truth is anything you put on the leather to keep the surface protected from moisture and stains is going to darken the leather. Sun will also darken the leather. I personally like a saddle that earns its darker color, it looks good. One more thing that might help you when you are cleaning your saddles for spring. Make sure you get them clean before you oil them. If you dont you are doing more harm to the saddle than good. Putting an oil coat over dirt or grime is terrible on tooled leather. Get it clean and let it sit for a day before you oil it. The best way I have found to clean it is to use pressurized air from a compressor. Take your saddle, to a garage they will let you blow it off for free. Bring a stiff brush with you and brush it while you're blowing it. That sure gets it clean. Its also good for cleaning the sheep hair under the saddle.
appy4me
Reg. Jul 2005
Posted 2009-03-08 12:14 PM (#100876 - in reply to #99904)
I love the CPR, it saved my old pony saddle from mold.
For good average conditioning, I use 100% pure neatsfoot.   Tucker recommends using conditioners, but they don't soften as much as oil does.
