Sealing floor
Last activity 2009-03-11 8:53 PM
12 replies, 7611 views
chadsalt
Posted 2009-02-18 4:09 PM (#99698)
Subject: Sealing floor
1000100100100100
I was talking with a guy at work about sealing the deck on my flatbed trailer, trying to find the cheapest option.  He told me that he uses, used motor oil.  Doesnt get much cheaper, Ive always got some used oil around here.
I suspect that would be too slick for a horse trailer, but might work for something that is exposed to the sun/elements.  Any thoughts?  What are you guys using?
genebob
Reg. Nov 2007
Posted 2009-02-18 4:28 PM (#99699 - in reply to #99698)
Subject: RE: Sealing floor
I use "used oil" on the floor of my manure spreadesr twice a year. I learned it from my father-in-law. He gave me his 400 bushel spreader that is close to 40 years old and it is still in perfect shape. I also put it on my flat deck trailer. Once it soaks in it is not slippery at all. I like to use an old watering can with the big nozzle (like a shower head) for even distribution. Seems to protect the wood from UV rays and definitely from soaking in moisture.
AQHA 123
Reg. Oct 2008
Posted 2009-02-18 4:30 PM (#99700 - in reply to #99698)
My dad used old motor oil for fence posts and it worked well. Some folks use it on their horses feet too. I think there are better things for a trailer deck but nothing cheaper.
Edited by AQHA 123 2009-02-18 4:33 PM
Marla
Reg. Mar 2008
Posted 2009-02-18 6:15 PM (#99706 - in reply to #99698)
500
You are right, the oil is too slick for a livestock floor, but works very well for hay trailers, equipment trailers, etc. We always thin the oil with a little diesel fuel before applying.
Marla
greyhorse
Reg. Nov 2005
Posted 2009-02-18 6:50 PM (#99711 - in reply to #99698)
I use 50% boiled linseed oil and 50% Diesel. It drys out pretty fast and isn't slippery then. I've used used oil and Diesel before but it's pretty slick for a while.
chadsalt
Posted 2009-02-20 7:41 AM (#99782 - in reply to #99698)
1000100100100100
 I guess we will give the used oil a try, hopefully the tractor doesnt come sliding off the side.......
Posted 2009-02-20 7:53 AM (#99783 - in reply to #99698)
My flatbed has a pressure treated pine floor. Most of the year it's sitting out in the weather. For about 5 months of the year it's under the shelter loaded with hay. What could I use to treat the floor with and not contaminate the hay?? I sprayed it when it was new with some of that Olympic water sealer stain..... That stuff exaporated about as fast as I put it on, within a month the water would no longer bead up on the wood surface. I used a 1 gallon pump up garden sprayer to apply the Olympic sealer. I guess with it being treated wood to begin with, it don't need much of anything on it. Best thing would be leaving it under a shelter all of the time.
Edited by retento 2009-02-20 7:54 AM
Posted 2009-02-20 9:39 AM (#99791 - in reply to #99783)
Originally written by retento on 2009-02-20 8:53 AM
Here you go Retento:
http://www.woodsealants.com/index.html:
I use it on my deck and docks.
Edited by gard 2009-02-20 9:43 AM
Posted 2009-02-20 10:43 AM (#99795 - in reply to #99698)
GARD... You don't imagine, it will make the hay taste funky? There will be about 50 bales next to the wood for about 4 months. That Olympic water seal that I used, smelled the high heaven for three or two weeks after I put it on. If had been on the trailer for 7 months before we parked it with the load of hay...... of course, it had pretty much already weathered away. This particular trailer is a PGS7 Proline, 7 ton, 20' gooseneck with a 5' pop up dovetail. We try to leave it parked under the shelter in the fall, loaded with 200+ bales of grass hay.
http://www.southag.com/Trailers/pgs7.htm
chadsalt
Posted 2009-02-20 11:01 AM (#99796 - in reply to #99783)
1000100100100100
Originally written by retento on 2009-02-20 7:53 AM
I suspect I would just treat it with whatever at the begining of its empty/outside cycle.  Should all be cleared up by hay time, then it will be out of the elements anyway.
Posted 2009-02-20 11:33 AM (#99802 - in reply to #99698)
Retento,
I can't answer directly to your question about hay. I've had very poor results with the Olympic and Behr products on the pressure treated wood of which my docks and deck are constructed. During the summer they are constantly exposed to bright, direct and reflected hot sunlight, the immersion into the lake water and rain. During the winter, they are subjected to a severe eroding environment, the frozen lake and topside wear including ice, snow and freezing conditions.
The Olympic and Behr products were coatings that didn't last the first year. The TWP isn't a coating, instead it soaks  into the wood like many good petroleum based products. Two coats produced enough protection that the water still beads after two year's of traffic and weather wear. Additional coats can be added at any time to provide additional protection.
The product dries completely, and because it resides inside the actual cellular structure of the wood, instead of a being a surfactant, I would think that it would have a minimal impact on anything laying on the surface.
If you're interested in this coating, call the manufacturer's number and ask for a tech support person who can answer your specific questions.
BOL              Gard
Edited by gard 2009-02-20 11:45 AM
gabz
Posted 2009-02-20 6:14 PM (#99816 - in reply to #99795)
1000100100100252525
Why not put pallets under the hay on the trailer? Then you can use a high quality sealant and not worry about the hay absorbing the chemicals.
chadsalt
Posted 2009-03-11 8:53 PM (#101157 - in reply to #99698)
1000100100100100
So I used the oil on the trailer.  Went pretty well, just sort of slopped it on with a bucket and rag on the end of a stick (guess that would be a mop?).
It was a little slick at first, but after about a week I wouldnt say it was any slicker than new/green, treated lumber.  Guess Ive found my cheaper way to treat the deck.
