replacing trailer axle
Last activity 2009-02-12 1:53 PM
14 replies, 18261 views
goin9-0
Posted 2009-02-12 11:17 AM (#99358)
Subject: replacing trailer axle
what is a ballpark price to replace a 5000lb torsion axle?
I have a 3H alum Sooner BP and i have been blowing the RR tire on it.  The tire is also showing weird wear on the inside.
I'm figuring worse case senerio is a bent axle and was wondering what the ballpark on that repair would be.  Im in oklahoma.
((im not sure they are 5000lb axles, might be 3500))
thanks!
Tresvolte
Reg. Feb 2008
Posted 2009-02-12 11:26 AM (#99360 - in reply to #99358)
Subject: RE: replacing trailer axle
Where in Oklahoma?
Posted 2009-02-12 11:28 AM (#99361 - in reply to #99358)
Is it a Dexter axle? If so, then this page may give you an idea of what the parts price would run...
http://www.dexteraxle.com/parts_store
http://www.dexteraxle.com/torflex_axles
Posted 2009-02-12 11:43 AM (#99362 - in reply to #99358)
I'm going to hi-jack this a little bit, just seen this on the Dexter site. Last week or so we were talking about the advantages and disadvantages of trailers with triple axles, then I seen this at the bottom of the Dexter page.....
CAUTION: Triple axle assemblies are not recommended for Torflex axles.
What are the trailer mfg.'s using if Dexter don't recommend the Torflex. I know with the three axle setup, you would need the trailer running as level as possible to keep the front or rear axle from being over loaded. I haven't seen any of these newer all aluminum trailers with leaf springs. Are all these three axle trailers running air suspension? OR... Do they have torsion axles?
goin9-0
Posted 2009-02-12 11:48 AM (#99363 - in reply to #99360)
im in southwest oklahoma.  Comanche.
trguy4820
Reg. Jul 2008
Posted 2009-02-12 12:22 PM (#99365 - in reply to #99358)
Torsion axle replacement will run between $500 & $700 depending which axle you have. You have probably bent the spindle which will cause the odd tire wear.
goin9-0
Posted 2009-02-12 12:28 PM (#99367 - in reply to #99365)
Originally written by trguy4820 on 2009-02-12 12:22 PM
ok, really going to show my "girl-ness" here, but can you replace just a spindle?  or is that part of the axle?  and if so, what does that repair run?
trguy4820
Reg. Jul 2008
Posted 2009-02-12 12:33 PM (#99368 - in reply to #99367)
I'm sorry but I might have misled you a little. The bent spindle requires the entire axle be replaced. It is machined as a part of the axle and cannot be replaced.
Tresvolte
Reg. Feb 2008
Posted 2009-02-12 1:11 PM (#99375 - in reply to #99362)
Originally written by retento on 2009-02-12 11:43 AM
The ones I have seen have been torsion axles.
Tresvolte
Reg. Feb 2008
Posted 2009-02-12 1:18 PM (#99376 - in reply to #99358)
Call this guy... http://www.reznertrailers.com/contact.htm   I have done business with him in the past. He takes good care of people. He is just north of you at Duncan.
Edited by Tresvolte 2009-02-12 1:19 PM
deranger
Posted 2009-02-12 1:20 PM (#99377 - in reply to #99368)
5001001001001002525
Originally written by trguy4820 on 2009-02-12 1:33 PM
You are partially correct.  Spindles can be replaced on SOME axles, but not all axles.  Most axles have the spindle welded on or bolted on.  It's not machined as part of the axles as a rule.  The axle is a tube and the spindle is usually a different piece of metal that is machined to accept the bearings, seals and nut to capture all the hardware behind it.  It's usually the axle that bends, not the spindle.  I've ordered blank axles and changed the "hub assemblies" over to the new axle.
What's a little weird about this tire problem is it's the rear axle?  Most damaged axles are on the passenger/curb side and it's usually the front axle that has run into a curbing, sometimes at road speed and bent the axle.
deranger
Edited by deranger 2009-02-12 1:25 PM
Kay
Posted 2009-02-12 1:38 PM (#99379 - in reply to #99358)
50025
Not too weird.  We see this sometimes when the trailer is not running level, but up in the front putting disproportionate weight on the back axle.
goin9-0
Posted 2009-02-12 1:40 PM (#99380 - in reply to #99358)
i wonder if i took it to large semi trailer repair facility, if the axle could be straightened?
yes it is the rear axle causing me problems.  I bought this trailer used and its given me trouble on the RR tire ever since.  No matter how good of a tire i purchase....maybe why it was for sale in the first place...oh well live and learn i guess.  I LOVE LOVE LOVE this trailer, if it wasn't killing me in tires.....
maybe unrelated, but yet an observation, but i seem to blow the RR tire more often if i have it loaded with 3 horses.  If i only haul 2, i put them in the front 2 stalls.
Its a 1997 Sooner with a large front tack.  Pulled with a 2005 Dodge dually.
Edited by goin9-0 2009-02-12 1:43 PM
Tresvolte
Reg. Feb 2008
Posted 2009-02-12 1:44 PM (#99381 - in reply to #99358)
This place can. The location on W Reno in Oklahoma City.
http://www.fleetpride.com/fp_p/branch.html
goin9-0
Posted 2009-02-12 1:53 PM (#99382 - in reply to #99381)
thanks for all the suggestions and knowledge!  Very much appreciated!
